Thread: Ultra Frame pool band
    Sep 2016
    Winnipeg, Manitoba, Canada
    1
    Unhappy Ultra Frame pool band
    I live in Canada and have to take my Ultra-frame down for the winter. I had just emptied the water and my dog ripped the band that the "legs" or vertical supports run through. Does anyone know if this can be fixed or if you can use the pool without these? I may have to throw the otherwise pool away. Thanks
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,319
    Re: Ultra Frame pool band
    I think it has a small value to holding the legs tight to the pool. Perhaps you can find a purge ratchet-type strap to place around the bottom? I recall this subject coming up a few years ago, I will see if I can locate the thread soon.
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Agreed with PA, as long as you keep the legs straight while filling the pool next year (Use a large level) you should be fine. I have seen previous post where they have used a ratchet and strap on the pool like PA mentioned.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
