Thread: Hello from West Virginia! :)
    Hi there!
    I`m just popping in to say exactly that^ and ask a question that has likely been asked several thousand times before.. which is.. dose putting an abg pool 3ft into the ground suddenly become an in-ground pool?
    I am certain it will change the barrier aspect of the law ( going from 4ft barrier to a 6 ft), but I cannot find anything top tell if anything else changes. I have read here and across the web, that because it is still considered an "ABG pool" because of its construction, it will not cause home insurance to rise. But I am still wondering what if anything changes due to lowering 3ft into the ground.
    Anyway, have a great rest of you day and thanks ahead of time for any info you can give .
    Roxanne
    Roxanne Pitts
    West Virginia
    semi buried- ABG-Steel wall construction-18'x 54"
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,933
    Re: Hello from West Virginia! :)
    Hi Roxanne,
    Welcome to TFP!
    A partially buried AGP does not reclassify it. It's still an AGP.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Welcome to TFP!
    Jun 2014
    13,188
    Nice to have you with us. Enjoy the site.
