Results 1 to 17 of 17
Thread: What is this?
    Mamamartini's Avatar
    Sep 2016
    Wilmington, OH
    34
    What is this?
    Pool came with new house. Seller was an investor who never lived in the house and didn't maintain the pool (renters did), so I don't know the pool history. Is this a return that's been capped off? We only have 2 returns, so a 3rd could really be beneficial for circulation in this big pool. Is there any risk to taking the plug out? What are possible reasons they capped it? What else could it be besides a return?
    Thank you!
    Viking Spas 300 gallon ETS-5 hot tub, TF-100
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,019
    Re: What is this?
    Mama,
    I would suspect an unused vacuum port. They normally have a flapper like cap, but it could have broken and was just replaced with a plug.
    Could also be a unused return, but then the only reason to plug it would be due to a leak, and plugging just one end would not solve anything.
    If you can add a picture of your equipment pad, showing the valves and surrounding equipment, you might get a better answer.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: What is this?
    Best odds are that it is NOT a return due to the location on the stairs and the cap. There would be no good reason to cap 1 of 3 returns.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Sep 2016
    Wilmington, OH
    34
    Re: What is this?
    Quote Originally Posted by Jimrahbe View Post
    Mama,
    Let me know if you need more pictures!
    In my equipment pictures, can you see the electrical "station?" The switch under the outlet is for the pump, but we have no idea what the switch on the other side is for. Any ideas about that? We have two pool lights, but they don't work, so we aren't sure if that's what the switch is for.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,970
    Re: What is this?
    looks like you have 3 scution lines from the pool to the pump. 1) Skimmer 2) main drain and 3) ? could be a port for a suction side cleaner?
    Divin Dave,
    Sep 2016
    Wilmington, OH
    34
    Re: What is this?
    Quote Originally Posted by Divin Dave View Post
    someone labeled them: deep end skimmer, shallow skimmer and main drain.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,970
    Re: What is this?
    Ah ok. So its not a suction cleaner port. hummmm? I wonder what it could be....
    Divin Dave,
    Jul 2014
    Bedford, TX
    7,019
    Re: What is this?
    Do you have two skimmers?
    I see no reason not to take the plug out and see what happens. There should either be suction there, or pressure.. if nothing, I'd stick the plug back in.
    Sep 2016
    Wilmington, OH
    34
    Re: What is this?
    There are two skimmers. I will take the plug out and see what happens.
    Thank you!
    Sep 2016
    Wilmington, OH
    34
    Re: What is this?
    Update...it IS a functioning return!! So exciting!
    Re: What is this?
    It's a step return. Typically, there is a separate line going to the step returns. Step returns are sometimes called step jets because some people install hydrotherapy jets there so that people can sit on the steps and get jet action like in a hot tub (That's the intent anyway. They rarely, if ever get used like that).
    Don't know why it was plugged or why it doesn't have its own plumbing line.
    The extra switch probably goes to the lights. You can open the lights junction boxes to see if power is getting to the lights.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Re: What is this?
    I bet it used to have a circulating return. They are often found on pool steps.
    Custom Molded Products Deluxe Rotating Massage Jet - Gray - 23315-031-000 - INYOPools.com
    Keep an eye out (just in case) for any lowering of water level in the pool just in case there was a leak issue.
    Re: What is this?
    Did water start coming out as soon as you removed the plug?
    If the line was getting return water pressure the whole time, then the pool would have been losing water if the line leaked.
    Support the site
    Sep 2016
    Wilmington, OH
    34
    Re: What is this?
    Water came out immediately...is that good or bad?
    I don't understand this whole leaking issue, and that worries me.
    Jul 2014
    Bedford, TX
    7,019
    Re: What is this?
    Mama,
    I would not be too worried about a leak. Since this is a pressure pipe, plugging the end would not stop a leak, so there must have been another reason to close it off.
    I'd add an eyeball and use it..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,238
    Re: What is this?
    I agree with Jim. Water coming out immediately is good. That means the line was pressurized and full of water so if the pool wasn't leaking before then it isn't leaking now.
    Jul 2016
    Nebraska
    38
    Re: What is this?
    check the pressure in the other 2 returns, perhaps they capped it so that they could get more force on the other 2. We have 4 returns but only 3 really worked until we made the PB install eyelets and now they all shoot out water.
    11k vinyl in ground pool with SWG, DE filter, gas heater & auto cover.
