Thread: Pinholes ?? Help ???
    Sep 2016
    Canada
    1
    I have taken down my ultra frame Intel
    I noticed there are a lot of pin holes on the bottom but they are not all the way through?
    Is this normal? What can I do ?
    When I hold it up to the sun, there are a lot !!
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    Re: Pinholes ?? Help ???
    Hi Douta,
    I don't have an answer for you, but I remember another poster had a similar problem. I think their issue turned out to be termites or ants that caused the pinholes. I can't remember their solution though. You could try searching the forum for termites or ants and pinholes. Good luck!
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Aug 2013
    Chicopee, MA
    43
    I have that problem here in Western Ma. Changed my liner 2 years ago and had to have an exterminator come spray the liner area to the tune of $200. I don't have the biological name for them, but these little buggers thrive on moisture and vinyl. You got to spray
    POOL-24ft Above ground, Vinyl 16000 gal
    FILTER-Hayward EC-40 DE filter
    TEST KIT- Taylor -K2006
    Dolphin Robot Cleaner S50
