Results 1 to 9 of 9
Thread: Pre-disolving CYA
    May 2015
    Fullerton, CA
    642
    Pre-disolving CYA
    Tried something new, put cya in a 5 gallon bucket and filled it with water, 6 hours later there is still a bunch at the bottom. Also this stuff never seems to disolve 100%. I can still see tiny little particles floating in the water. So when is it considered 100% disolved so i can pour into the pool?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    39,279
    Re: Pre-disolving CYA
    It never will, that is why we do not recommend that method and suggest putting it in a sock and suspending it in front of a return jet or putting the sock in the skimmer. It needs water flow, and frequent squeezing to get it to dissolve.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,800
    Pour it on in and just circulate it.
    May 2015
    Fullerton, CA
    642
    Ok so this bucket of cya isa bust? I have more i can use, i have doen the sock method, just thought i would try this out.
    Most is disolved. So its either stir it and dump it or down the drain and then back to the sock.
    Sep 2013
    Connecticut
    728
    As Woodyp said, just pour it in and circulate. It hasn't gone bad or anything; just not very soluble in a relatively small volume of water, as you found. If you search the forum, you'll find that a number of people have tried pre-dissolving CYA. Even in hot water it isn't a great success.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Yep, pour it in and dont clean your filter for a week.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Quote Originally Posted by Titan7 View Post
    You have what is known as a "saturated solution". You may be successful with a larger bucket, unless the undissolved is not really cyn but some undissolved contaminant. You could see the same thing with a glass of water and trying to dissolve sugar or salt.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    May 2015
    Fullerton, CA
    642
    Thx, got it handled, poured the disolved liquid in, then the sock method for the remaining, that was not fun. So much for trying something new, lol
    Aug 2014
    Northern IL
    4,615
    I have to say that I know where this method has worked. They hung the CYA in a sock in the bucket so they could still squeeze the sock. Then, periodically, they would scoop out the solution and add it to the pool. Then add more water to the bucket, etc. until it was all dissolved.
