Thread: Intex drain plug for hose homemade replacement options?
    Jun 2012
    Michigan
    154
    Trying to drain an Intex AGP with the single drain plug that it came with, but wondering if anyone has any luck fashioning a homemade drain plug for an additional hose to double the draining speed on a pool with two drain holes.
    Intex 16x48 UltraFrame AGP, included filter pump
    Sep 2013
    Connecticut
    728
    Re: Intex drain plug for hose homemade replacement options?
    Meh... I never drain with that garden hose size fitting (I assume Intex pools have something similar). Much quicker drain speed by siphoning over the edge with a pool vacuum hose (larger diameter means higher flow rate).
    I don't believe there is any good reason to risk making an additional hole low down on the pool for draining purposes.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
