Thread: Chlorinating while on vacation
    Jun 2016
    Jurupa Valley, Ca / Southern Ca
    I recently bought a house with a 15,000 gallon in ground pool. Not knowing anything about pools until I stumbled on TFP, I was going to Leslies and following their advice. I was chlorinating with Trichlor in a floater. I went on vacation in June and had no one to care for the pool. I was told by Leslies to heavily shock while I was away to keep the chlorine level high enough to avoid algae growth. I followed Leslies advice and dumped 4 bags of their shock (Dichlor) in. Needless to say, my CYA level has gone from 40 to 100 over the past few months while following Leslies advice. I am going out of town for 2 weeks and don't want to make the same mistake. Should I use a floater with Trichlor while I'm gone or do I pour a large amount of liquid and hope it lasts until I'm home. If the chlorine is the way to go, is there an amount to put in for that 2 week period that will last. I live in Southern California so the weather is always a challenge. It could be 100 degrees or it could be 75 degrees. Thank you all for your assistance
    15,000 gallon in ground pool. Pentair 1 1/2 hp variable speed pump. Pentair 420 sq ft cartridge filter. Sandscape finish. Barracuda auto pool sweep.
    Sep 2016
    Magnolia, TX
    Re: Chlorinating while on vacation
    You have to either use a stenner or liquidator.
    Aug 2016
    Mid Missouri
    Seems like there should be a cheaper option than a $200 product.
    Welcome to TFP!!!
    There is no way to maintain adequate FC levels for 2 weeks unattended unless you have a SWG or a stenner pump or a Liquidator or get a friend/family member to add bleach occasionally.
    Using more Trichlor is also going to raise the CYA, just like the shock did.
