Thread: Why should we drain the water level to 6" below skimmer for pool closing?
    Sep 2016
    Suffield, CT
    3
    Hello everybody.
    I read the instructions on pool closing about lowering the water level to 6" below the lowest opening. I have heard conflicting advice on this step for years.
    If I drain it that low, that means I will need to put in that much more water next spring. And my well provides hard water, so I would have to go through those exercises to remove the hardness.
    I have a skimmer plate that keeps the water separated from the skimmer, and also the plug for the eye.
    I have never lowered it that much except to replace the skimmer one summer.
    Can you explain the rationale for this step?
    Thank you!
    Vinyl, 24' round above ground pool (15,000 gallons). 1 hp pump, Sta-Rite cartridge filter.
    Auto-Chlorinator using 3" tablets.
    RyanMcC's Avatar
    Aug 2013
    NH
    211
    Re: Why should we drain the water level to 6" below skimmer for pool closing?
    Just guessing, but it gives room for snow and rain to build up without getting it into your pipes and refreezing.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Connecticut Al View Post
    Hello everybody.
    Thank you!
    You don't need to drain below the skimmer and even if you do heavy rain / snow melt may fill it back up so you need to properly winterize no matter what you do. I leave my water right at the skimmer level. You just need to make sure you blow out all of the returns and the skimmer line and then put in something to absorb any ice expansion in the skimmer. Many people (including me) will pour some anti-freeze down the skimmer line and then cram the empty jug into the skimmer around the gizmo.
    That's all i have ever done and have never had an issue. For what it's worth the diver who found the hole(s) in my liner two years ago had just come from a pool that had not been winterized at all (2 years ago was a brutally cold winter) and not one of the lines had cracked or had any issues. I'm not advocating that by any means but it just illustrates how tough that plastic can be (think of plastic ice trays).
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    328
    With a cover for the skimmer opening and a plug for the return you don't need to lower the water. I have and aquador cover and plug my return and don't lower. You will need to keep an eye on the water on top of your cover. as long as you can leave the bottom of the skimmer open and all water will drain out, your ok. you might want to put something in to absorb the effects of water freezing in it. ( noodles, old 20 oz soda bottle, etc)
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Sep 2016
    Suffield, CT
    3
    Thank you all for your advice.
    It is a good point that snow and rain will displace the water under the cover. (I do try to keep the snow off, and I do drain the water on top).
    I use the Aquador brand cover over the skimmer entrance as well.
    And all the hoses and the filter parts go into the basement.
    (I am very impressed with the number of folks replying, it is very helpful to have these conversations).
