Thread: Vacuuming Pool Before Closing
    Aug 2015
    Petersburgh, NY
    When I attempted to close my pool last weekend, I ran into a problem with blowing out the main drain. I am in the process of getting a Cyclone, and I am waiting for that to arrive.
    In the meantime, my pool has been drained 6" below the skimmer. I hooked up the pump, return, and main drain hoses again temporarily, so I can continue to circulate the water, and chlorinate as needed. However, the bigger issue now is how I keep the pool clean until I can close it.
    Is there a way I can vacuum the pool, while the water level is 6" below the skimmer? Normally, you can keep the vacuum hose under water so air does not get into the pump, but that is not possible now. Is there another way to do this? How can I keep the pool clean, without re-filling the pool, until I can close it? Any ideas would be appreciated.
    - Chuck - My pool: Fiberglass (Aug 2014); 19,324 gallons, 1.5-hp pump; Hayward Sand Filter
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    Re: Vacuuming Pool Before Closing
    hose into the skimmer to fill it up before attaching vacuum?
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    Yes, fill the hose as mentioned earlier and it should prime pretty easily. When done, take the hose out but leave the water in the hose outside the pool (maybe suspend somewhere).
    If you are getting a Cyclone, then look at the modified cover that I put together. Just an idea.
    Modified Cover for Swimming Pools
    Modified Cover for Hayward Super Pump for Closing Swimming Pool
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
