Thread: Polaris Stuck in corner
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    Not sure what it's officially called, but half the shallow end of my pool is around 18 inches deep, then there are two steps that span the entire width of the pool and lead into like a 4ft shallow end which slowly slopes off the 9ft deep end.
    My Polaris is constantly stuck on the left side, trying to get up that first step. Sometimes it makes it up the first step and gets stuck on the second step. Very rarely does it ever make it up to the 18 inch shallow deck. It's starting to rub a spot on the plaster in this area where the wheels just constantly churn on it until it kicks into reverse which gets it unstuck and heading in the other direction until it ultimately gets back to that same spot. Rinse. Lather. Repeat.
    Aside from buying another cleaner, does anybody have any neat tricks or tips for this problem (which i'm guessing is common).
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    Apr 2013
    Sacramento, CA
    2,769
    Re: Polaris Stuck in corner
    Generally a Polaris doesn't like steps so the fact that is not climbing does not surprise me.
    How old is this baby? I'd look at the wheels are they worn or rough?
    They sell various factory rebuild kits that are not cheap but replace things like the wheels which may help with your problem
    Apr 2015
    tucson, arizona
    1,061
    You might try adjusting the thruster jet downwards giving the cleaner a little more lift, or just remove some hose so the cleaner won't reach to the steps. But as was posted, the Polaris wasn't designed to clean steps or shallow shelfs
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    155
    I'm not sure how old it is, I inherited it when I bought the house/pool. It seems to be in pretty good shape and doesn't look ancient.
    I was thinking about replacing the tread on the wheels. I usually just brush the shelf and stairs into the rest of the pool and let the polaris pickup the debris out in the main part of the pool. So i'm really not worried about it climbing the stairs, I'd like to just keep in from getting stuck and more importantly rubbing spots on my plaster.
    Memphis, TN.
    Taylor K-2006
