Thread: Preventing Mold/Algae on Pool Deck or Waterfall
    I'm getting REALLY wore out with bleaching and power washing my pool deck every few months. Its hot and humid down here in the Sunshine State, and I can't seem to keep the mold/algae from growing in the cracks of my waterfall, and all along the fake rocks around my pool. The side of our water-slide goes from clean and beautiful to black and disgusting in a month or so. When the weather cools off and we're not using the pool as much, I'm hoping to treat the whole deck and decorations with SOMETHING that will help keep this in check.
    Any suggestions?
    Located between Tampa and Orlando, FL.
    13,000 Gallon (Approx.) in ground kidney bean shaped pool with Vinyl Liner, Artificial rock features around most of it, plaster/concrete water slide, and 2 tier waterfall.
    200 sf Jandy cartridge filter - P6RA6F-206L Sta-Rite Max-E-Pro 1.5HP Up Rated Pool Pump - Black plastic (cheapo amazon deal) solar collector on barn roof.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,926
    Re: Preventing Mold/Algae on Pool Deck or Waterfall
    About the only thing that will be effective is sealing the deck and waterfall rocks with sealer. There are some pretty good products out there that you can use to keep the natural look if thats what you want, or shiney if thats what you want. Or somewhere in between.
    The downside is, it may be a bit more slippery, and you'll have to reapply it every few years.
    Divin Dave,
