Thread: TA 400 is that okay
    May 2009
    Azle, Texas
    24
    TA 400 is that okay
    I just received my TF100 test kit and here are my readings:
    PH: 7.8
    FC: 9
    CC: 1
    CL: 5
    TA: 400
    CYA: 25
    The pool calculator did not indicate that I needed to do anything. But it shows my TA should be 100-120, mine is 400 and yet it did not tell me to do anything. Just wanted you expertise thoughts on this.
    I am so glad I found this site. I have had horrible experiences in the past two years with the pool store. I am hoping to have a nice clear pool this year since I have found this site.
    27 ft round AG, vinyl, 17,100 gallons, 2 HP pump, sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TA 400 is that okay
    Welcome to TFP.
    400 is much too high. You'll be fighting pH always climbing.
    Read this article in Pool School about lowering your alkalinity http://www.troublefreepool.com/pool-...l%20alkalinity
    30,421
    doglover,
    do the TA test again and this time wipe the dropper tip in between every few drops. That test has a static electricity issue that sometime results in smaller drops which may have skewed your results.
    Butterfly's Avatar
    South Carolina
    10,045
    Hey doglover,
    They got you covered on your TA.
    Have you been shocking your pool? Your CC of 1 indicates a need to shock. If you need to know how, just ask.
    How does your water look?
    Also, I'd knock that pH down to around 7.4-ish.
    Your horrible-experiences-with-the-pool-store days are over!
    Congrats on your TF100 test kit and welcome to the forum
    You're done SLAMing when:
