Results 1 to 17 of 17
Thread: New Pool Build in LA County - Gunite Inspection Advice?
    Exclamation New Pool Build in LA County - Gunite Inspection Advice?
    Hello All,
    We are finally starting our new pool and as many know the number of choices and differing advice is staggering.
    Our pool will have a shotcrete shell and I have been told by one builder that he recommends a shotcrete inspection w/ cores while others have said it is unnecessary. The cost quoted to me is $475ish. So the questions:
    1. Do the experts out there recommend a shotcrete inspection w/ cores?
    2. If so does $500 sound about right for costs?
    3. Where would I go to find an inspector?
    4. Would the fact that the Nozzleman is ACI certified and/or the shotcrete came premixed from a batch plant and certified by a weighmaster change your decision (or the lack of the two for that matter)?
    Any other advice before I sign tomorrow?
    Thanks!
    Jan 2016
    Mesa, Az
    542
    Re: New Pool Build in LA County - Gunite Inspection Advice?
    You can have test cylinders cast and broken by a qualified lab much easier than coring after the fact. Cores are usually a last resort method.
    Quote Originally Posted by BigEinAZ View Post
    Thanks. So how do I do that? :P
    Do I have the PB pour a cylinder on the day the Shotcrete is being shot? And is there a list of qualified labs?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Quite a few cities in Southern California require samples to be poured and tested. I would say it's not necessary unless required the inspectors/city.
    Ask to see the tickets from the cement truck driver to confirm they brought what you are paying for.
    Who did the engineering for the pool? Pool Engineering Inc out of Anaheim?
    What Shotcrete contractor?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Hi Brian,
    No idea on who is the Shotcrete contractor. Engineering I assume is by the local company doing the pool. Unless they all farm it out to one place?
    I will certainly ask for the tickets - if the mix comes from the plant I am less concerned then if they are mixing at the nozzle. Firm has a good rep around here both with couple of people whose pools they have done and also with the pool pros that service pools around here. This is mostly my OCD.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Shotcrete isn't mixed at the nozzle like gunite is so unless unless the contractor is telling the driver to dump a bunch of water into the drum, you should be getting exactly what is stated on the ticket.
    Keep an eye on the guys if they start reaching for your garden hose. It would be a good idea to ask where the rebound will be placed and who/when it will be hauled off.
    If you look at the notes on the engineering details in your plans, several cities are listed that require a special inspector to either oversee the entire shoot or at least be there to see samples prepared. See if any of the cities pertain to you. LA City is known for being especially difficult, often requiring their own licenses for contractors and material suppliers...some of that may trickle out to the county.
    I'd be shocked if Pool Engineering didn't do the structural portion of your plans.
    -Brian-
    POOL BUILD
    Brian,
    Interesting. I figured most of these guys did not do their own engineering but I didn't think it all got farmed out to one company. We are signing our contract tomorrow and I want to make sure I am not missing anything as far as the shotcrete goes. Good to know the shotcrete can't be mixed at the site.
    BTW: My pool equipment is pretty much a mirror of yours.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    I'd say over 90% of the pools in the area use Pool Eng.
    You'll be very happy with the equipment. The only things I'd recommend differently is a Raypak 406A instead of the Master Temp and a Stenner acid pump over the IntelliPH (if you are going that route).
    -Brian-
    POOL BUILD
    Nov 2015
    Woodland Hills, CA
    176
    Where are you located? Depending on where you live and what kind of soil you have, you might need a deputy inspection has to be present:
    http://netinfo.ladbs.org/rreports.nsf/0/533b2048299ec7ec8825694b006d91af/$FILE/24346L-2011LABC-10-01-2012.pdf
    https://www.ladbs.org/docs/default-s....pdf?sfvrsn=14
    Pool Engineering did my pool and totally missed the surcharge from the hill and wall next to the pool. I failed the steel inspection and had to pull out a bunch of 3/8 and replace it with 1/2" While they updated the drawings at no cost, I had to eat the change ($800).
    O/B Woodland Hills, CA : O/B12x30 inground with 6x6 10-jet spa, 10,500gal, 6' Baja deck, 42" spillway, All Jandy: 400k heater, 2.7 HP VS pump, 1.5HP booster spa pump, SWG, Intellelink controls, (4) LED lights, cartridge filter and BlueSquareQ360 infloor cleaning system, Eclipse drain, glass tiles, Zanzibar white pebble finish. Broke ground 2/18/2016, completed 8/16/2016. TFT 100 kit.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Frank, did they actually do a site visit and do the plans? Usually they provide a generic engineering sheet and approve the site plan they are given. If a designer did the plans then the error falls on him, not the engineer as they only engineered the job they were given.
    -Brian-
    POOL BUILD
    Quote Originally Posted by bdavis466 View Post
    I was originally going to go "fully automatic" with an IntelliChem unit and IntelliPH. However, after reading on the forums here I decided against that. I saw many people recommend the Stenner instead of the IntelliPH. I am still deciding on that as I will have a pool man who will add acid weekly so may not be as much of a necessity.
    I had specified a Pentair MasterTemp 400K ASME HD but I am interested to know why the Raypak 406A? Costs, performance, both?
    Also I thought that you got a better warranty through Pentair if all of your equipment was Pentair instead of mix and match?
    Thanks for all the advice and help.
    Quote Originally Posted by Frank Rizzo View Post
    The PB has indicated a deputy inspector will be on site but my understanding was that they are not there the whole time - i.e. they are there for 15 to 30 minutes and they go to the next job.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    3 or more items from Pentair will get you the 3 year warranty, so you are already there.
    The Raypak will be less than the heater you spec'd by $4-800. You do not need the ASME or cupronickel heaters. Save your money on those.
    Wait on the acid pump and get it out of your head right now that you'll have a pool service. Taking care of your pool is easy and there are thousands of people on this site that are eager to help you do it.
    -Brian-
    POOL BUILD
    Nov 2015
    Woodland Hills, CA
    176
    Brian
    Yes they did and saw the existing 3 foot retaining wall (built in the 1970's. of 4" CMU). But their E & O only limits them to fixing the drawings...(and an apology).
    The pool man is not because I think it would be particularly hard to take care of the pool but more of a time constraint. I am holding off on the acid pump for now. I may put it in, in any case but not a high priority item. Can you point me to a good thread where people have discussed why the Stenner instead of the IntelliPH (aside from price of course)
    I also checked with the PB and yes the design will Pool Engineering Inc. The shotcrete will be at 4000 PSI (in contract - initially was going to do shotcrete at 3000 psi) and a deputy inspector will be present the whole time.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Brian
    Well that certainly makes it their fault then... How did they miss that????
    -Brian-
    POOL BUILD
    Nov 2015
    Woodland Hills, CA
    176
    ^ I dunno and probably never will. The steel guy was pretty cool and it ended up being about $850 if I recall. And the Grading inspector wanted a soils report so I had to hire and Engineer (Oro) which was another $800. It was kind of a blessing because if you remember waaaaay back to March, we got a good amount of rain and I ended up with a lot of junk under the rebar. When they pulled out all of the #3 it gave me a chance to get it all out before the laid the #4. They also changed the spacing to 4" OC in the deep end and on the surcharge wall.
    I still had to have a deputy inspector present for the shotcrete and he witnessed the slump test. I never heard of anyone else having to go thru that.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Quite a few cities require the special inspector and I bet more will soon enough. I actually like the slump tests to make sure you get what you paid for.
    -Brian-
    POOL BUILD
