Results 1 to 12 of 12
Thread: Stripped drain plug on pool pump housing
    May 2013
    Massachusetts
    148
    So yeah, I did this. I guess it's actually on the pool pump basket itself, not really the housing.
    Anyone successfully fix this? Because another PP housing is like $250 and I've already bought it once before.
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,656
    Re: Stripped drain plug on pool pump housing
    I fixed one with JB Weld. Of course, you'll never be able to open that drain again, but I never used it anyway.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,352
    I actually removed my plugs last year (closed myself). First year, the pool company removed them. This year, I am leaving them in the pump housing as I do not need them to close the pool. Of course they are not the best of quality. Even with the cover on, plugs out, heavy rain and snow, there were no water issues or damage. I really see no need to remove the plug(s) unless you are using an air compressor. Personally, I used Teflon tape and did not over tighten them.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    May 2013
    Long Island NY
    419
    Quote Originally Posted by weird_tolkienish_f View Post
    My threads are shot also, the way I finally got it to stop leaking was doubling up a piece of plastic Baggie and the threads finally held. Basically I just made the drain screw fatter .
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    May 2013
    Massachusetts
    148
    Quote Originally Posted by jeffchap View Post
    This is what I'm leaning towards I think. I don't know why I messed with these stupid drain plugs in the first place. Wanted to get the water out I guess.
    I don't need to use them.
    DE, Hayward Filter
    Loud pump
    May 2013
    Massachusetts
    148
    I think if anyone is reading this for the future: hand tighten these plastic drain plugs only! Do not use any tools!
    DE, Hayward Filter
    Loud pump
    Catanzaro's Avatar
    Jul 2014
    2,352
    I tighten by hand and then 1 turn only with a screwdriver. That is all that is needed!
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,551
    Run a 1/4" npt tap through the hole & your good.
    If the 9/16" flat cracked off a torched flat head driver will back them out.
    May 2013
    Massachusetts
    148
    Quote Originally Posted by PoolguyinCT View Post
    I've been looking for an excuse to buy a tap and die set, would retapping really work? It wouldn't make the hole too big?
    DE, Hayward Filter
    Loud pump
    Dec 2009
    Virginia Beach, VA
    131
    Sure it'll work as long as you do it carefully and you have enough plastic to work with. Just make sure you get it started nice and straight and remember to make like 1 turn clockwise and then 1/2 turn counter clockwise over and over until you're done. If you really boogered up your threads you might have to go to the next bigger size in which case you'll have to find a larger plug. Remove the housing (or the whole pump) as doing it upside down is a recipe for failure (unless you're just cleaning up your threads). Good luck.
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    If it's just a broken off plug, sharpen the end of a flat screwdriver, heat it up with a flame or torch and then tap it into the plastic plug with a hammer. Allow a minute to cool and then unscrew.
    Make sure to center the screwdriver so that you don't touch the threads. Tap gently with the hammer.
    Support the site
    Jul 2014
    Connecticut
    1,551
    Nice jamesW.. That's what I meant by "torched flathead"
    Great instructions buddy
