Thank Goodness For Pool School! CH Question
May 25, 2009
14
Yay for pool school! Before the pool water was cloudy, dirty and numbers extreme. My way would have taken the entire summer to correct, but reading the Pool School section I accomplished a lot in a week! Currently, my water appears to be balanced, clean and sparkling!
Specifications:
Viking Pool (ceramic fiberglass), 9000 gallon, equipped with a s.w.g.
Water:
FC - 4
TC - 4
pH - 7.2
TA - 60
CH - 160
CYA - 60
I see my numbers are normal, except CH. Maybe the CH is low because I mostly filled the pool with soft water from my house. What do you pool experts think?
What kind of pool do you have? Vinyl pools don't care about CH unless you have a heater. If you have a heater, follow the heater manufacturer's recommendation for CH.
I did the saturation index and my pool water is actually corrosive. Increasing the calcium levels will help off set the corrosive environment.
The CSI is actually one applicable to plaster surfaces. It does not predict corrosion on metal surfacts. However low calcium can cause other problems with fiberglass pools such as cobalt spotting and higher incidence of staining.
Really? I was celebrating when I finally got my CYA down to 60ppm. Last year it was over 150 at one time.
With a SWG you want to run with a higher CYA, helps the whole system run more efficiently. Because chlorine gets added automatically the level will tend to fluctuate less and so you can run it "closer to the line" than you really want to do with manual addition of chlorine.
--paulr
