Thread: why CYA 70
    Sep 2016
    tullahoma
    1
    why CYA 70
    SWG, 220000 gal ,2 1/2 hayward pump ,cartridge filter, t cell 15...new to site!
    why is it recommended to keep CYA at 70 if it gobbles up Chlorine, makes my swg work harder and needs a higher FC to stay "healthy"?
    marty f
    Mod Squad JohnT's Avatar
    SW Indiana
    9,085
    Re: why CYA 70
    Welcome to TFP!
    You have it backwards. CYA protects chlorine from UV degradation which makes it easier for your SWCG to maintain the chlorine level. Though higher CYA levels require higher FC levels for sanitation, the CYA reduces the chlorine used up by sunlight meaning you typically add less chlorine to the pool with high CYA levels unless you get algae and need to SLAM.
    Texas Splash's Avatar
    Jun 2014
    12,928
    Re: why CYA 70
    Hello and welcome to TFP! Actually, it's the other way around. The additional CYA level "protects" the valuable chlorine generated by your SWG so it can maintain the proper FC level more efficiently. At lower CYA levels, the sun will grab your FC faster than desired resulting in higher run times/percentages.
    John beat me to it.
