Thread: Help rain water has washed away sand from under my pool
    We have had a ton of rain lately and it has caused some sand to be washed away from under my pool right at the edge. It is an old pool and was already installed here at the house when I moved in. Can I dig down and force some more sand in the void to reduce the crater in the pool liner? I really don't want to drain the pool to fix it. I just opened it up a few weeks ago and the water bill will be huge if I drain and refill again.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help rain water has washed away sand from under my pool
    Welcome to TFP
    The weight of the water is going to make it virtually impossible to get any sand back under the liner.
    wouldn't something be better than nothing?
    SW Indiana
    9,199
    Quote Originally Posted by dgramo
    If you dig out enough to get access to the liner, the liner will probably bulge out under the pool wall or rip. There is more than 50 tons of water in a 24' AG pool.
    what if I just forced it in without digging out to the liner?
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    If you try to dig it out to put something in there the weight of the water will force the liner out under the wall perhaps tearing it and you dont want 15000 gal of water running all over your yard. If you try to force something up in there you risk puncturing the liner as well ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
