Results 1 to 11 of 11
Thread: First New England closing
    May 2013
    Needham, MA
    148
    First time closing with our new pool. Actually a company is coming to close as it was included with our new pool. I will be doing all the chemicals though. When do most of you in the New England area close? The heat pump is still doing a great job of keeping the water at 85. However, with cooler temps predicted for the next week, with low temps in the low to mid 40s, I am thinking now may be the time to remove the solar cover, turn off the heater and let the water get down into the 50s. My maintenance is already more that it was all summer with my neighbors leaves landing on and staining the cover.
    Am I pulling the plug to early? Should I give it a couple more weeks?
    14x28 Kidney IG vinyl pool, 9250 gallons. Pentair 1.5hp superflo variable speed, Pentair Clean and Clear 240 Cartridge filter, Pentair IC40 SWCG, Hayward Heatpro 110,000k heat pump, Pentair Intellibrite 5G LED lights, Polaris 280, Taylor K-2006 test kit
    May 2013
    Long Island NY
    419
    Re: First New England closing
    Quote Originally Posted by rmclain73 View Post
    Your not to early I wouldn't think. I just put the cover on myself a few days ago and most yrs. what triggers my closing is when the leaves start to fall. I put the cover on about a month before I blow the lines and pull the pump. I like the water temp. to be constantly below 60.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by samt View Post
    I think that's the key for closing things up. For me it's just too early as the temp's are higher than 60 and it's just a little more Bleach to keep things right till I close
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Messman750's Avatar
    Jun 2015
    Groton New York
    35
    I live in upstate ny. My water temp is 70and slowly falling. I hope by next weekend the temperature is falls into the low 60's and close it up.
    32x16 inground chlorine. 23000 gallon with diving board
    vinyl liner 1hp hayward super pump. Waterway sand filter new in 2014.
    maytronics dolphin m200 robot. I live in central NY.
    TF100 kit Taylor speedstir. Sonos audio
    30,503
    I am certainly not a closer here in Florida but over the years, we see consistently clearer opened pools when they were closed late. Water temps below 60 seems to be a key.
    Sep 2016
    West Suffield, CT
    2
    I live in West Suffield, CT and typically close my pool the 3rd or last weekend in September and every year since 2007, my water has been clear when opening in the spring. I do use a chemical closing kit (I realize there are other options and that's one reason why I joined this forum) from an online retailer. I am closing my pool tomorrow.
    The *ONLY* issue I have had are lots of worms in the pool which stain the liner, but I believe this is due to switching to those 'water boxes' to hold down my cover. This year I'm going back to bags and I'll see how the worm situation is next spring.
    EDIT: I should've mentioned that I use a solid cover.
    Chip ~ My Pool: 20x40 Rectangular IG with Jacuzzi steps in deep end ;), ~32K Gal, WhisperFlo 1HP Pump, Pentair CCP-520 cartridge filter, Sani-King Perform-Max 940 inline chlorinator, AquaCal HeatWave SuperQuiet Pool Heat Pump, Dolphin M5 Supreme Robot
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,352
    I had a lot of worms this spring, but luckily no staining. The "water boxes" are great, but the lids blow off. This year, I will use long pieces of wood as well. My pool will be closed either next week, or the following week, and I only use PolyQuat 60 with a FC of 50% SLAM level. The pool is always opened one month early (before the holiday), and I leave the cover on for 24 hours with the filter running. The pool water is crystal clear. Vacuum up and ready for the pollen season. I believe it is the mesh covers that can really cause a mess if you wait too long in certain parts of the country before you open your pool.
    If there were not so many leaves falling in the pool, personally I would keep it open until later October, early November (right before freezing). If you open up early, you can close early. I believe that is the secret in not waiting too long in the Spring to open the pool.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Jun 2014
    Marmora, New Jersey
    46
    do most people normally use a winter algaecide or just shock prior to closing/?
    Blizz
    10,000 gallon white fiberglass pool.. in ground pool
    DE filter,,"Hayward EC65"
    1 hp, Hayward Superpump
    May 2013
    Long Island NY
    419
    Quote Originally Posted by fmblizz View Post
    Blizz
    I think you will get different answers on this. For me I close late when the water temp is in the 50's and I open in the spring when the water is in the 50's and alls I do at closing is shock the pool.
    If my routine was to close early when the water temp wasn't constantly in the 50's I think I would be adding polyquat 60 to guard against any algae.
    Aug 2013
    Chicopee, MA
    43
    Have had pool for 20 years. This my first closing after converting from baquacil(don't use it). I usually close about 2nd week Sept. I have someone do it for me because of heavy stairs. Reason I close early because of leaves got a lot of em. I have used the polyquat just to ease my mind. Will see next season what it will bring?
    POOL-24ft Above ground, Vinyl 16000 gal
    FILTER-Hayward EC-40 DE filter
    TEST KIT- Taylor -K2006
    Dolphin Robot Cleaner S50
    Scout101's Avatar
    Aug 2015
    North Kingstown, RI
    186
    I'm closing next week in RI. Temp is sitting around 60 in the water, so close enough. Came from a total swamp this spring (I'm the new owner), so whatever it looks like in spring will be better than this year!
    No way I'd still be paying to heat the pool, even if I wasn't ready to close. That's gotta be adding up. Plus once the air temp is down in the low-mid 70s, doesn't seem like anyone wants to use the pool even if the water is warm, so we've been done a couple weeks now and just waiting for the colder temps.
    I'm definitely ready to put it to bed for the winter!
    IG Vinyl, free-form 25' x 40', 25,000 gal., Hayward 1-1/2 hp Superpump, Hayward S310T 500lb. Sand filter, AquaLogic T-Cell 15 SWG and Automation, Hayward H300 Milivolt 300k btu NG heater, TF-100 Test Kit w/spinner
