Results 1 to 13 of 13
Thread: Best/cheapest/easily found algaecide..
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    160
    I know this has probably been asked a gazillion times, but my search function doesn't work for some reason...
    What is the best/cheapest/most easily found algaecide available? My numbers look great with my CC at 5-6 and my free CC at 0 but I have a little bit of algae trying to form...
    TIA!!
    Intex 20x52 above ground pool-
    8632 gallons
    1 man 4 woman Bullfrog Hot Tub
    http://www.flickr.com/photos/pitguy3/se ... 763801706/
    ROLL TIDE!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Best/cheapest/easily found algaecide..
    There is none better than liquid Chlorine/Bleach. Not for the money or effectiveness. Some though, will have ingredients you don't want like Copper. Bleach has none of the bad side effects, and properly maintained, it will never let you down.
    How are you testing and maintaining the pool?
    Essential Links:
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    160
    I have a TF-100 test kit that I've been using. I haven't had to SLAM my pool yet this year due to the Free CC at zero.. Do you think that will help?
    8632 gallons
    ROLL TIDE!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,203
    You seem to be confused about terms:
    CC=Combined Chlorine
    This is the chlorine that is in the process of sanitizing the pool. If you have more than about 0.5ppm, you have an issue.
    FC=Free Chlorine
    This is the good stuff that is available to clean up anything that gets in the pool.
    If you have algae, your chlorine is either too low for your CYA level, or has been allowed to get too low recently. Without knowing your CYA level there is no way to know how your chlorine level measures up.
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    160
    My CYA level is about 65-70. You are correct.. I had them backwards. I try to keep my FC at 5 or 6. Ideal would be 8. My CC's have been at zero for a while and are currently at zero..
    8632 gallons
    ROLL TIDE!
    39,279
    Sounds like you let the FC get a little too low.
    With visible algae you need to follow the SLAM process until you pass the 3 criteria to stop.
    You do not need algaecide.
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    160
    Good deal... I was under the impression that you really only needed to SLAM if your CC's got too high. I will start my SLAM hopefully tonight or tomorrow.
    8632 gallons
    ROLL TIDE!
    39,279
    You need to SLAM if there is ever any problem in the pool: high CC, algae, cloudy water (likely due to algae), etc.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by pitguy3 View Post
    Excellent! Let us know if you have any questions.
    Essential Links:
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    160
    OK I have one... LOL!! My TA is at 70 and my PH is at 7.8... Should I get these in check prior to slamming?
    8632 gallons
    ROLL TIDE!
    Aug 2014
    Houston tx
    2,531
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    pitguy3's Avatar
    Jul 2009
    Birmingham, AL
    160
    Yes I have... Doesn't mention TA though.. That was my main question.
    8632 gallons
    ROLL TIDE!
    Aug 2014
    Houston tx
    2,531
    Check and adjust the PH to between 7.2 and 7.5. The PH test isn't reliable during SLAMing so make sure to take care of this before.
    Marla
