Thread: How to detect if a gizzmo cracked or not?
    Sep 2015
    Setauket. Long Island. NY
    51
    I want to close my pool in couple of weeks, but what's the safest way to detect if a gizzmo cracked or not? or any other backup solution besides a gizzmo?
    thank you.
    20'x 40' 32000 gallon pool. (built approx in 2001.)
    Vinyl liner (replaced in 2017)
    Pentair FNS Plus 48 DE filter
    AutoPilot Salt Chlorine Generator. Taylor K-2006 (FAS-DPD)
    Pentair Whisperflow pump w/ Variable Speed V-Green 165 Pool Pump Replacement Motor
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: How to detect if a gizzmo cracked or not?
    Hi, you could turn it upside down and fill it with water and check for leaks. Some people put some rv antifreeze in a plastic bottle. Just anything that ice can crush but sinks(you dont want it to float on surface.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Sep 2015
    51
    Thank you for your advice. Two more questions if you don't mind.
    1. The only thing I am worrying about using plastic bottle, (e.g. coke bottle or porland spring water bottle) is that I wonder if this type of bottles will be cracked by ice in winter. If that's the case and water can flow into the bottle, then there is basically no use at all. Do you have any suggestions what type of plastic bottle will be most suitable?
    2. Is rv antifreeze suitable for pool use? Let's say if I pour some into the skimmer when winterizing, is it safe for next spring after pool open? If it is safe, do you have any links/products you can suggest?
    thank you so much
    banditig's Avatar
    Sep 2015
    Ohio
    466
    You can use left over bleach bottles, I think 2 litre would work. RV antifreeze is safe but when you open the pool try to pump it to waste. Don't use automotive radiator antifreeze.
    https://www.walmart.com/ip/16213488?...&wl13=&veh=sem
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by bfang711 View Post
    thank you so much
    True RV antifreeze is mostly used for winterizing potable(drinking, washing) water plumbing systems in RVs & boats. So it's safe to ingest in small quantities & no issue with pool water. That being said I agree with banditig that when you open the pool try to pump it to waste.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Aug 2016
    New Haven CT
    62
    The "geezmo" I have doesn't have a plug in the end, there is no provision for this. Maybe there was a change in models over the year?
    Gary
    New Haven, CT
    16 x 32 x 8 in-ground vinyl , sand filter
    22,000 gallons
    Leslie test kit, TF100 test kit
