Thread: seems clear at first, then appears slightly pink???
    Mamamartini's Avatar
    Sep 2016
    Wilmington, OH
    34
    Using my TF-100, and I'm curious about something...
    When checking for FC and CC, my sample appears to change from pink to clear, but after sitting for a bit, it gets the slightest pink tinge to it. Do I just go with the first moment it appears clear, ignoring whatever happens after it sits? It happens when I check for both FC and CC.
    Thank you!!
    Viking Spas 300 gallon ETS-5 hot tub, TF-100
    Jun 2014
    15,894
    Re: seems clear at first, then appears slightly pink???
    Go with the first reading as soon as it clears. Letting it sit will always revert back to a light pink color.
    Sep 2016
    Wilmington, OH
    34
    Thank you!
