Thread: Borates question
    sddiver's Avatar
    Mar 2016
    Oceanside, Ca
    Borates question
    I am planning to add boric acid to our pool for all the benefits it provides but was wondering if it was better to wait until next season or if it would be ok now? Does the BA need to be added each year or does it remain in place longer than a season?
    Thank you for any input.
    18500G Freeform IG pool & spa. 39'x19' Wet Edge Satin Matrix Tahitian Tropical. AquaPure 1400 SWG, JXI 400K BTU HTR, VSSHP270AUT 2.7HP VS PMP, 460CF + CS150 Cart Filter, PFPF2.0 2HP jet pump for spa jets, 1HP wtr ftr pmp Jandy LED RGBW 9W Nichless lights (3x-pool, 1x-spa), 2 - 24" sheer descents, 4 - deck jets, 2 - LED Laminar jets, Construction start 5/5/16 - Fill date 8/9/16. SD County SoCal (Oceanside). TF100 test kit
    JoyfulNoise's Avatar
    May 2015
    Re: Borates question
    Borates only leave through pool water exchange with fresh water. So you can add it now or later, it won't change what you put in unless you expect to lose water over the winter.
