Thread: Just refilled due to high CYA and algae, help
    Aug 2016
    Altoona, PA
    17
    I followed the recommendations I received the other day and, with a CYA of 180, drained all but a foot of my pool. I had the pool refilled earlier today and just retested everything. Here are my new levels:
    FC = 11
    CC = 0
    CH - 150
    TA = 70
    CYA = 70 (I was surprised it's still this high)
    pH = a little above 7.2
    I tried using pool math for the first time and I think this is what it's telling me to do:
    add 3 jugs (378oz) 8.25% bleach
    add 24oz borax
    add 2lb 3oz baking soda
    and it still says to replace 29% water (I literally only left a foot in it)
    Is there an order I do this in?
    It's late and I just got home from a crazy 13 hour day at work.... can I just pour the 2 jugs of bleach I have on hand now and recheck tomorrow or is this going to get ahead of me again?
    Thanks!!!
    15,000 gal AG, Hayward Pro Series top mount sand filter, Power-Flo LX pump, July 2014 install, TF-100 w/ speed stir, well fill
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: Just refilled due to high CYA and algae, help
    All of those numbers are in the recommended range. I wouldn't change anything. It is probably telling you to drain based on CYA being above 50. I don't know why it would say to add 3 jugs of bleach. 11 is well within range for CYA of 70, FC/CYA Chart Maybe you don't have the right settings selected toward the bottom of PoolMath?
    Aug 2016
    Altoona, PA
    17
    Oops, sorry, I forgot to mention the green part. So the 3 jugs is for shock level. Prior to draining, it was very cloudy green for a few weeks and it still has the green tint with the dilution. I used hundreds of dollars worth of pool store chemicals with no results, so I'm done with them and ready to SLAM. I'm new to this site so this is all a little unfamiliar to me. Are my other levels good to start the SLAM process? Unfortunately it might have to wait till Saturday because of my work schedule.
    Thanks!
    Jun 2015
    Missouri City, TX
    83
    Your other levels look fine to start the SLAM. CYA is a little on the high side, means you'll need a bit more liquid chlorine than desirable to get to and maintain shock level but it's not impossible to manage.
    If you can't start the SLAM yet, can you at least do an Overnight Chlorine Loss Test (OCLT)? If your pool was cloudy green before, it sounds like you need to SLAM, but the OCLT will confirm if you have algae.
    Graeme // 15k gal 29x15 geometric IG w/750 gal spa, Wet Edge Northshore Tahoe, travertine coping and decking, Clean & Clear Plus 420 sq ft cartridge filter, Intelliflo VS pump, 1hp water feature pump, Easytouch 8 w/wireless handheld, Racer pool cleaner, 400,000 BTU Max-E-Therm heater, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5G LED lighting, bubblers, pencil jets, TF-100 w/SpeedStir, Borates & Salt. Finished and filled June 2015!
    Aug 2016
    Altoona, PA
    17
    Good morning. I took your suggestion and just completed the OCLT. I actually did not have any chlorine loss. My FC stayed at 22. I'm still concerned though as the water has a tint of green left and is still cloudy. If I need to SLAM, I'll have time this weekend. So I think maybe I'll brush the walls and floor this evening and then repeat the OCLT.
    Thanks.
    DFW, TX
    24,042
    Yes, green and cloudy changes things a bit. if you continue ue to pass the OCLT I would raise the FC to about halfway between target and shock level, FC/CYA Chart, and brush daily for a few days to a week to clear it up.
