Results 1 to 14 of 14
Thread: Is my wall coming apart?? ** Pics added**
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Hi, I was just outside adding some chems and noticed directly under one of the upright caps on the inside of the pool under the liner is a lump about 1.5 inches wide that runs all the way down. When I press on it I can't tell what I'm feeling...screws or what but I have not seen this before and I think I would have noticed it. Help????
    This pool was installed about mid April.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Re: Is my wall coming apart??
    Is it where the wall connects?? It is perfectly flat under all the other uprights.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I would get the people who installed it to come back and look at it. It sounds like a warranty issue to me ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    So its not normal to be able to "feel and see" where the wall comes together?? Maybe I just haven't noticed but I really think I would have....
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Can you take a picture and post it for us too see. I think what your seeing and feeling is where they joined the pool wall together but I am not 100 % sure on that. A pictre would really help the experts determine what itis .
    Les
    Helpful Links:
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    I'll get out there today and take a pic. Can you feel and see where your wall comes together?
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Ok here are some pics, kinda hard to see but the "lump" runs all the way down.
    Casey's Avatar
    SW PA
    10,423
    Does it look like this?
    This is a pic of my pool bolts. I have it duct taped and wall padded.
    If so, it's just where the wall bolted together. It's normal. The reason why it's behind an upright is to hide the ugly bolts on the outside of the pool.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Re: Is my wall coming apart?? ** Pics added**
    I think it kinda looks the same, don't you?? Except I don't have wall foam on mine so maybe thats why mine sticks out more?? Am I just being paranoid??
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I watched them install my pool and they used a thick strong metal strip with screws to attach the walls together where the circle met. I can feel mine, so I am thinking that is what you are seeing/feeling.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Casey's Avatar
    SW PA
    10,423
    Quote Originally Posted by keri1973
    It looks the same to me... it's normal.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Thanks! That makes me feel better
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    If you really want to put your mind at ease you can remove the cap that is on your top rail and look down inside of that upright.
    I'm sure it's just the bolts for the wall. Mine is the same way.
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Thanks alot, I'll prob take a peek tomorrow.
