Thread: Hayward 4820 DE filter - First year, and Observatiosn?
    May 2014
    Weston, CT
    24
    Hey Guys,
    This was my first year using the 4820DE. What a huge difference compared to the old grossly undersized cartridge filter.
    That said, when I went to close the pool this last weekend, I tried a backflush and didn't notice much debris coming as viewed through the observation window port thingamajig.
    Truth be told, it was a while since my last backwash and recoating of the filter... Probably 1.5-2 months.
    After the pool was closed, I opened up the filter to see all grids were covered with sludge, and non was removed during the backwash.
    I pulled the grids and hosed everything off well, reassembled and all is fine.
    My question... Is this normal? Is this because I didn't backflush regularly and things gummed up? My pump is pretty powerful and I thought should clear old filter media from the grids.
    What should I do differently next year?
    Bryan
    25K In-Ground Vinyl, circa 1990. Hayward C800 with 1.5 HP Max-Flow Circa 1990???? In line Chlorinator. Raypak Heater.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Re: Hayward 4820 DE filter - First year, and Observatiosn?
    Hi, Not sure what is going on here. Could be too much DE added at first. 48 sg ft model needs 6lbs or approximately 9 1lb coffee cans clean. Double check the plumbing of the waste line and valve.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    tech@hayward.com
