Results 1 to 7 of 7
Thread: How to connect a Shop Vac to the skimmer and return line
    Jun 2014
    Hauppauge, NY
    17
    After closing my pool the first year I realized it was a pain to blow out the lines. So I looked though the plumbing section at the local home improvement stores to see what I could rig up.
    What I ended up doing was to use pvc union connections for connecting the skimmer lines and return lines to the filter and pump.
    I store the pump inside over the winter along with some of the piping.
    With pvc unions everything comes apart easy in the fall and goes together easy in the spring. Occasionally I need a new o-ring.
    To blow out the line I bought an extra unit and use half of it, a short section of 1-1/2 pvc pipe glued to the union and a 1-1/2" to 2" flexible couple to attach the pvc pipe to the shop vac hose.
    Now everything is held together well and the hose does not blow off. You don't need two people to blow out a line.
    I also bought a few extra union and pipe plugs to cap the skimmer line, return line, and inlet and outlet on the filter.
    Also makes it easier to pour in antifreeze into the skimmer and return lines now. When I installed the union I made it so they were all vertical. You can out them horizontal and make you blow out adapter with an elbow to make pouring in the antifreeze easier.
    It's a little work installing the unions but you only need to do it once. And any leaks I end up with in the spring are easy to fix with a new o-ring.
    This is not screwed together tightly. My other union for the return line is the other half so I need to change it when blowing out the return line. If you think ahead a little further then me you won't have to do that.
    The flexible rubber coupling (No-Hub) is for 2" pipe, the union and pipe is 1-1/2". So you could use a 1-1/2 x 2" flexible coupling.
    Once the hose clamps are tighten the shop vac hose does not come off. If your hose does not have a lock onto the shop vac you will need to figure out how to secure it so it won't.
    -20' x 40' Inground vinyl - 35,000 gal
    -Hayward super pump 1.5hp - 1.5" pipe
    -Hayward Sand Filter S244T
    -Aquabot Classic (old but still works)
    -Stenner install in progress.
    themadangler's Avatar
    May 2016
    Southampton, NJ
    126
    Re: How to connect a Shop Vac to the skimmer and return line
    Quote Originally Posted by Bill1974 View Post
    Any pics?
    Diamond Pool 20'x40' Lazy L, approx 33,000 gal vinyl liner, Hayward s244T filter, Pentair Intellichlor Ic 40( new May 2016) replaced computer pool cpsc35, inter mastic T40404R, A.O.Smith UST1152 super pump 1.5 hp, Hayward heater, not working or by-passed, Polaris 360
    May 2014
    Toronto
    7
    Hard to picture without pics
    Jun 2014
    Hauppauge, NY
    17
    I will add some images when I get home in a little bit. I will try to add them to the original post.
    Jun 2014
    Hauppauge, NY
    17
    Pictures added for those watching
    Sep 2013
    Connecticut
    728
    Thank you for adding the pictures. Useful tip!
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    May 2016
    Southampton, NJ
    126
    I will try to adapt this to my pool needs
