Thread: Calcium Hardnes, Total Alkalinity and Ph high
    Sep 2016
    Lawrenceville/Ga
    3
    Hello,
    I just got the TF 100 test kit and tested my pool. The results are as follows,
    FC 7.5
    CC 0
    Calcium Hardness 550
    Total Alkalinity 220
    CYA 60
    PH 8.2, I keep lowering the PH with dry acid but it keeps rising back up.
    According to pool math I must drain pool by 1/3 and add 78 oz of dry acid.
    Is there any other way to adjust pool parameters without draining?
    Above ground, 24000 gallons, chlorine 1.5 hp pump, 26 inch sand filter.
    mas985's Avatar
    Pleasanton, CA
    11,765
    Re: Calcium Hardnes, Total Alkalinity and Ph high
    Welcome to the forum!
    I regularly deal with high CH and TA because of our fill water. It is possible to maintain a pool with high CH and TA but you will need lots of acid to do it. I would target a PH of 7.2 until the TA comes down to a more reasonable level which it will over time. However, you might want to use muriatic acid instead of dry acid because it will be more economical.
    If you want a quicker process, you can try this: Pool School - Lower Total Alkalinity
    Mark
    Jan 2012
    'burbs of Augusta, Georgia
    7,706
    Do you have any idea how your CH got so high?
    I ask because my fill water here in Georgia is only about 45ppm of calcium.
    Don't worry about calcium in a vinyl pool- it doesn't need it.
    Yip
    Sep 2016
    Lawrenceville/Ga
    3
    hi,
    Well I went to the local pool store three times this summer and the pool guy kept giving me buckets of calcium hardness for the pool. I thought it was strange but I just went with it as I hadn't found this site yet. I drained some water today....not 1/3 but as much as I could. I am adding the 78 oz of dry acid and leaving it pump all night. I will check again in the morning. I'm so glad to find you guys.
