Thread: Diamond Brite Abalone Shell Equivalent
    Jun 2016
    FL
    901
    Ive seen enough horror stories of abalone shells damaging the Diamond Brite quartz-based plaster to sway me away from adding shells to our plaster. It seems to be a bad mix between the two. Is there an alternative or equivalent to abalone that works well with DB? Or is the only option just to add more quartz "chips"?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Diamond Brite Abalone Shell Equivalent
    Glass beads are a nice option. I just dont know much about the particulars of adding Abalone.
    Essential Links:
    Jun 2016
    FL
    901
    Would that make the surface rougher like pebble? I've seen glass added to pebble but never heard of adding it to a quartz based plaster. Ill have to check into that.
    Brian - UNDER CONSTRUCTION: 17K gal SW Gunite IG. 17'x23'(w/shelf)x34'. 650sf. 114' perim. 3.5'-5' depth sports pool. 7'x11' sun shelf, 6'x8' spa. Intelliflow VSP, IC60 SWCG, CC420 filter, 4 LEDs (2 Globrite and 2 Intellibrite). Hayward 140K BTU heat pump. Pentair EasyTouch 8 automation. Ivory travertine deck. 8"X16" travertine coping. NPT lightwaves Aquamarine spa tile and marker tiles. Undecided on plaster/pebble finish.
