Thread: AG skimmer closeing question
    rajung's Avatar
    Mar 2015
    This will be my fourth year closeing and never had a problem but wonder if there is something I should do that I haven't.
    I always disconnect both return, and intake from skimmer,lower water to 6 inches below return,plug return,and cover skimmer opening with a foam backed plastic plate,it fits snug but really not leak proof.
    Last year for the first time I decided to walk up the deck and check skimmer and it was full of ice.between winter freezing rain and snow the water level usually raises quite a bit.
    Even with the bottom of skimmer open to the ground it still plugged and froze shut.I'm afraid that maybe it will expand and split the skimmer box ,I have always left the lid on it.Thanks for info
    Doughboy AG 16' x 32' oval, 13,700 gal.
    AquaView by Doughboy 150lb sand filter model 0-1709-20
    PowerLine pump by Doughboy model 0-3047-200, 1.5hp-single speed-20amp
    Gulfstream electric heater-HE125-R-A
    Taylor K-2006 test kit
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    Re: AG skimmer closeing question
    You may consider adding a Gizmo (If they have one for AG pools). This will help with any expansion due to freezing temperatures. If not, placing foam inside the skimmer is another idea. Some member have used a small bottle (filled up 1/2 way with pool anti-freeze) to help with expansion.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
