Thread: "Green" low odor Muriatic Acid
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    166
    I bought this stuff at Home Depot - all they carry at ours:
    Kleen Strip Green Muriatic Acid.
    There is no indication of strength on the bottle or the sds other than "<30%"
    Many of the Q&A answers say 20% (and go on to reference TFP and pool math - awesome!).
    Is there any way to find out for sure, and if 20% is the number I'll give ya' a nickel if you add that to pool math! (That's a lie - but there is a "thanks" in it for you!)
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: "Green" low odor Muriatic Acid
    It is 15.7%, half strength, half of 31.45%, and it is already in a PoolMath. I'll take the nickel. I buy my MA at Lowes and it is "in the back" on a overstock aisle. They also have it in the paint department maybe find an old guy and ask if they carry the full strength somewhere.
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    166
    Hey, that works for me - thanks!
    Next time you're in Yakima swing by and I'll get you that nickel...
    I saw it a lowes after, but this is already bought so I'll use it up.
    I was enjoying the steady, slightly falling ph while I was on the trichlor tabs to get my cya up (new pool). It hit 40 this weekend, so it looks like I'm starting the tfp method. It came up fast - thought I would be able to hold out until closing.
    Mod Squad tim5055's Avatar
    May 2014
    Columbia, SC
    8,528
    Quote Originally Posted by pooldv View Post
    If your Lowes is link mine, the blue label full strength is going away. I talked to my store manager and he said that it was part of Lowes effort to carry a higher percentage of "green" products and the full strength stuff is no longer in his ordering catalog.
    TFP Moderator 39 X 18 23,000(ish) freeform gunite; built 2007ish; Pentair Triton II TR100 600lb Sand filter; 2 HP Pentair pump with 2.2 HP AO Smith single speed motor; 2 skimmers, 1 main drain, 4 returns w/waterfall, Stenner 45MHP2 3GPD running@ 60% - 15 gal Tank; heated by the sun CYA 200+ when I started - 50 now. Dolphin Supreme M5 Pool Cleaner. Hot Springs SX Spa, 285 gallon
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    166
    Quote Originally Posted by tim5055 View Post
    Lol "green"...
    Half the product = twice as many plastic bottles, twice the volume to ship, and coincidentally twice the relative price.
    DFW, TX
    24,042
    Right, it is green like this, $$$$$$$$$$.
