Thread: New to forum
    Sep 2016
    Monterey, TN
    2
    New to forum
    Hi everybody!
    Just joined after seeing what a great resource TroubleFreePool is. My goal is to learn more about water chemistry to more efficiently maintain our spa.
    Last year we switched from a above ground pool to a Water's Edge Trio spa with dual recliners which gave me less to take care of and a lot more relaxation. Of course, I miss the SWG and the robust sand filter but my wife and I are getting a lot more use out of the spa here in Middle Tennessee.
    Congrats on a great forum!
    Aug 2014
    Northern IL
    4,615
    Re: New to forum
    Welcome!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Re: New to forum
    Welcome to TFP!
    A spa makes winter a whole lot better! Here is how I maintain my hot tub. It's been working great for years. Some folks here add a Salton mini or other add on swg to their tubs.
    How do I use Chlorine in my Spa (or pool)?
    Sep 2016
    Monterey, TN
    2
    Re: New to forum
    Thanks for the welcome all!
    Pooldv, one of the first things I did was read your "How Do I Use Chlorine" article, great information thanks!
    Following that method I have been able to eliminate high TA and pH bounce, keep CYA to a lower level and not have to throw in a ton of chlorine to keep a good FC level.
    I am now working out a reasonable weekly maintenance procedure using MPS shock.
    Thanks again!
