Thread: Alkalinity drops too low on new water fill
    May 2016
    Naperville Illinois
    2
    When I'm adjusting the ph to balance the water in the tub the alkalinity drops to below 50 before I can get the ph to stop drifting. I know that alkalinity is a ph booster how do I keep the alkalinity up around 50 while I still have to use ph down to get the ph to stop drifting.
    mas985's Avatar
    Pleasanton, CA
    11,558
    Re: Alkalinity drops too low on new water fill
    Please post a full set of test results: PH, TA, CH, CYA
    How high does the PH get? With low TA, it should not get that high.
    Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    +1 to a full set of test results so we can see the whole picture.
    Have you added borates? You can raise TA with baking soda. More about pool chems here, Pool School - Recommended Pool Chemicals
    Review the pH, TA and borates discussion here, How do I use Chlorine in my Spa (or pool)?
