Thread: Putting pool water into hot tub
    slinkyra531's Avatar
    Jun 2013
    Millville, PA
    35
    So I am closing my pool this Friday and I intend to drain my hot tub and use my pool water to refill my hot tub. My pool water is crystal clear and balanced perfectly. I know that I will have to get my TA down using acid and aeration but other than that is there anything special I will need to know. I have been using BBB on my pool for years and this will be the first time doing this. I filled the hot tub this spring with the pool water but I had assistance from the person who helped me move and set up the tub. I am using a Technichlor drop over SWG in the tub. I think the only real concern I have is with putting all the bleach in the pool will my salt level be too high. I can't afford to fill the tub from the tap because I am on a well and things have been dry at my house in central PA. I would love to use Ahh-some to clean the tub thoroughly but again, I can't do multiple drains and refills. Any advice would be appreciated.
    24'x52" Above Ground Pool, Hayward Sand Filter, 1 HP Hayward PowerFlo Matrix Dual Speed pump, In-line Chlorine Feeder (only used when on vacation), AquaLuminator return light (customized with color changing LED light), all plumbing done with Schedule 40 PVC
    & 2004 Elite Spas Monterey Hot Tub (~400 gallons) with Controlomatic Technichlor SWG - Use Taylor K-2006 test kit with K-1766 addition and speed stir on both.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Re: Putting pool water into hot tub
    I think you are fine to do that. It doesn't seem likely that the salt will be too high. And still, a dilution will use a lot less water. Just be sure to fill the tub through the filter housing to avoid air lock if that is a thing with your tub.
    Jun 2013
    Millville, PA
    35
    Thanks for the reply. I will have to rig something up as my 50 backwash hose is about 5 feet short to reach the filter housing. I think I have some pvc pipe to finish reaching.
