Results 1 to 9 of 9
Thread: Trying to figure out my valve settings
    Sep 2016
    Cherry Hill, NJ
    7
    Hello,
    Still a relatively new pool owner, and trying to figure out what my valve positions do. Here is a bunch of pics of my setup: http://imgur.com/a/lykkE You can see that the position is slightly different when the waterfall and/or jets are on... I guess I'm trying to find out what happens when the valves are in different directions, but can't quite figure it out.
    Last edited by JohnPK; 09-22-2016 at 07:05 PM. Reason: Missing letters in my title
    Jun 2015
    Missouri City, TX
    83
    Re: Trying to figure out my valve set
    The short end of those valve handles indicates that flow direction is off. In your normal mode, flow is from the pool frogs through the two valves and back to your pool returns, which would be the right hand pipe (the one that feeds the intake for the booster pump).
    Looks like when your waterfall/jets are on the left valve opens slightly to allow some flow down the left return pipe. The right valve shuts off the pool returns and sends flow down the other pipe. So the left return is one of your waterfall/jets (I'd guess jets) and the other return is the other one (I'd guess waterfall).
    Have you played with the valve positions? From the waterfall/jet position, turning them one at a time back to the normal operating positions should tell you what each one does.
    Oh and welcome to TFP.....lots of great people and advice here.
    Graeme // 15k gal 29x15 geometric IG w/750 gal spa, Wet Edge Northshore Tahoe, travertine coping and decking, Clean & Clear Plus 420 sq ft cartridge filter, Intelliflo VS pump, 1hp water feature pump, Easytouch 8 w/wireless handheld, Racer pool cleaner, 400,000 BTU Max-E-Therm heater, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5G LED lighting, bubblers, pencil jets, TF-100 w/SpeedStir, Borates & Salt. Finished and filled June 2015!
    Apr 2015
    tucson, arizona
    956
    Your builder didn't set this up the best way. Should have put the waterfall and deck jets on same valve, then you would only have to turn one valve to operate. Be careful with the valve on the right if you put in the waterfall position you will be cutting off the water to booster pump and could damage pump if it runs without water
    Sep 2016
    Cherry Hill, NJ
    7
    Thanks for this! I played with the valves as you suggested... The attached picture is what they seem to do. The arrangements marked A, B, and D I get... those are normal settings (no jets/waterfall), and then B (right valve) controls the waterfall, and D (left valve) controls the jets. I guess I have no idea what setting C would do (if anything), and I don't think setting E or F are of any value, but I'm not sure if they would hurt?
    Better quality: http://i.imgur.com/Z34SRtm.jpg
    JohnPK,
    IG Gunite, 18,000 gal, 450 sq-ft surface, 2-deck jets & Waterfall, Jandy Pro Series HP Pump, Jandy CL460 Cartidge Filter, Polaris 280 Pool Cleaner, Polaris PB4-60 Pool Cleaner Pump, Jandy WaterColers LED Light, PoolFrog XL Mineral Pool Care System
    Sep 2016
    Cherry Hill, NJ
    7
    Quote Originally Posted by kadavis View Post
    So would that be arrangement C in my pic above?? That's what I'm struggling to figure out... Sorry for the dumb questions, but these are kind of confusing for a newbie! I guess I wouldn't run the cleaner and the waterfall at the same time though, so would arrangement B be ok - this seems to be the normal operating arrangement to run the waterfall?
    JohnPK,
    Apr 2015
    tucson, arizona
    956
    Re: Trying to figure out my valve settings
    No the pipe on the far right, which is your main return line would have to be switched with the pipe on the far left. as it is now the best way to run the pool cleaner pump is position A or C. You have to imagine that there is a diverter inside these valves, it is positioned exactly where the curved part of the handle is. So when you put it inline with a pipe the word off means that pipe is closed. You can position these valves to be open, closed or somewhere in between. As you noticed in picture D the valve on the left is only partially opened to the jet line, as you move ccw the jet line is opened more and you get more pressure to the deck jets as in picture E. In picture B you have all the water going to the waterfall, and in this position you should never run the booster pump for the cleaner
    Sep 2016
    Cherry Hill, NJ
    7
    Ahh, so I think I get this now... The curved short end of the valve indicates that flow is off?? So this labelled diagram of my valves and pipes should be correct?? http://i.imgur.com/7Ie1Uri.jpg I guess it makes sense, because when in position B, there is no water going to the returns, but I guess the waterfall is, more or less, the return when in this position. Thanks guys for your advice!!
    JohnPK,
    Jun 2015
    Missouri City, TX
    83
    Yeah that all makes sense, thanks a lot for the pictures. Jets are controlled by left hand valve, pool returns and waterfall by right hand valve. As I mentioned before, the short end of the valve handles have "off" markings, which tells you the pipe it is pointing at is closed off. If it's not pointing at a pipe (like the right valve in C) it means everything on that valve is open. Anyway here's what's happening in each position.
    A - All flow going to the pool returns (jets/waterfall off per the valve indicators)
    B - pool returns off, waterfall on (jets off on left valve)
    C - All pipes are open on that right valve, so both pool returns and waterfall are on (the reduced pressure at waterfall because the flow is now 50/50 split with the returns, unlike B. Jets off on left valve)
    D - small amount of flow to jets through left valve, rest to pool through right valve (waterfall off)
    E - all pipes open on that left valve, flow 50/50 split between jets and pool returns (waterfall off)
    F - All flow all to jets (returns and waterfall off)
    To kadavis' point, when running your cleaner you need to avoid having the left valve in position F or the right valve in position B as either of those positions will shut off the flow to the pool returns that feed the booster pump. All other positions should be ok, although you will see maximum flow at the cleaner in position A.
    If you want to run your water features at the same time as your cleaner, you can, but if you start splitting flow to the water features you should verify that you still have enough flow at the cleaner return for it work properly. Usually with your cleaner they supply a small flow indicator that connects where the hose goes into the wall and allows you to verify you have enough.
    I agree it would have been easier for you if the builder had put the water features on a single valve.
    Edit: see you guys got it solved while I was typing. Yes your interpretation is correct and the red markings indicate the pipes that are off.
    Sep 2016
    Cherry Hill, NJ
    7
    thank you both! I really feel like a learned a lot here!
