Thread: Safety cover support
    May 2015
    Pittsburgh
    18
    I have a 24x44 in ground and will be installing a safety cover for the first time. I'm going south for the winter and won't be here to tighten straps. Is it OK to put a few inner tubes in the center for added support?
    24x44 in ground. Premier earth filter, Hayward heater, sanitized with chlorine.
    Mod Squad JohnT's Avatar
    SW Indiana
    8,790
    Re: Safety cover support
    You tighten the straps when you install it to stretch the springs a specified amount and shouldn't have to do anything afterwards. You won't need anything in the pool but water.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    2,853
    They are designed to stretch (really compress the springs) so that the cover rests on the water when it snows. However, each cover manufacturer will specify the proper water level. It is usually in the range of 18" or less below the cover level. Of course you want the water level to stay below the waterline tile at all times while freezing is possible.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. Saltwater w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, salt cell, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2015
    Pittsburgh
    18
    It's an arctic armour 30 year. They say 18". Thanks. I'll drain it to 18" and just cover it. Thanks.
