Thread: HEEEELP with pool light
    Jun 2016
    Monterrey, Mexico
    34
    Well I am sorry to report that apparently the electrician connected the transformer backwards
    the GFCI breaker was tripping and he didn't know why
    now that he did the correct connection, the light won't turn on
    any guesses if he blew the light or what happened?
    im appalled
    intellibrite 5G white lamp 12V with a 120to12 volt transformer
    11'x21'x4.4'
    7.0K IG Concrete pool
    Hayward Swimpro 19" Sand Filter
    1HP pump
    Pentair Intellibrite 5G 500W equivalent white light
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    5,570
    Re: HEEEELP with pool light
    Puro,
    If by "backwards, you mean he connected the 12 volt secondary output to the 120 volt AC input, then I would suspect the transformer has gone to where all transformers go when they die!!!
    It may or may not have taken out the light itself.
    I suggest your electrician measure the output of the secondary and see what he gets. It should be 12 to 14 volts, but I suspect it will be zero volts..
    Jun 2016
    Monterrey, Mexico
    34
    It measures 13.2V, but the light is not turning on
    Thanks for the response
    im about to cry, is there a fuse in the lamp or something?
    ETA: the lamp has a fuse harness. We will be checking that tomorrow, hopwefully it would be the only damage since it costs 20 bucks
    if the circuit board is damaged it costs 350 dollars. My contractor would be in deep...
    11'x21'x4.4'
    1HP pump
    sddiver's Avatar
    Mar 2016
    Oceanside, Ca
    15
    i had the same issue with a transformer - i connected the hot from the GFI, but connected the neutral to the normal neutral bar in the load center causing the GFI to trip as soon as the relay tried to turn the lights on. I thought the transformer was bad but it was really just my own error - I needed to bring the neutral back to the GFI neutral otherwise the GFI senses a fault and trips (made total sense after somebody else figured it out!). Did the light ever work? are the connections at the transformer on low side well made to the light cord (sometimes the wire nut is hiding a poor/non-existent connection). it does appear that there may be a replaceable fuse assembly (see page 12) of the owners manual:
    http://www.pentairpool.com/pdfs/IntelliBrite%205G%20OM.pdf
    18500G Freeform IG pool & spa. 39'x19' Wet Edge Satin Matrix Tahitian Tropical. AquaPure 1400 SWG, JXI 400K BTU HTR, VSSHP270AUT 2.7HP VS PMP, 460CF + CS150 Cart Filter, PFPF2.0 2HP jet pump for spa jets, 1HP wtr ftr pmp Jandy LED RGBW 9W Nichless lights (3x-pool, 1x-spa), 2 - 24" sheer descents, 4 - deck jets, 2 - LED Laminar jets, Construction start 5/5/16 - Fill date 8/9/16. SD County SoCal (Oceanside). TF100 test kit
    If the pool light was connected to the transformer when it was energized backwards, your sparky applied 1200 V to a 12 V fixture. He should replace the fixture, and any wiring past the transformer since it was all exposed to excessive voltages.
    8.5k gallon IG pebble sheen play pool with Intellitouch control, Intellifo VF, IC 20, Rainbow tab feeder (not currently in use), Pentaire mystery cartridge filter with labels faded to the point I have no idea on the model, Intellibrite 5g LED light, Hayward Navigator. Adding IntelliPh and Crestron control next.
    Jun 2016
    Monterrey, Mexico
    34
    Update
    I called Pentair, they said most likely the fuse is blown, they don't know if the circuit board or anything else was damaged.
    The procedure should be to replace the fuse harness and go from there. They weren't a bit surprised about the "mistake"...
    11'x21'x4.4'
    1HP pump
