Thread: How to fix flange for Pentair IC40?
    wpbucher's Avatar
    Feb 2012
    South-Central Pennsylvania
    The black flange (glued to 2" pipe) of my Pentair IC40 has a crack in it. Of course, the PB configured without any space for a coupler, so I'm faced with replacing a bunch of stuff if I can't fix this.
    Not sure if the black flange is ABS, PVC, or CPVC.
    What glue can I use to attempt a fix?
    At the moment, it is producing a drip about every 2 seconds.
    Thanks for your help.
    2013 HotSpring Grandee with Ace Sanitizing System
    25K IG vinyl pool with Alps spillover spa and waterfall. Build Date: June 2013
    Triton II TR100 Sand Filter, Pentair Master Temp 400 natural gas pool heater, Intellichlor SWG, Rainbow Chlorine Feeder
    Pentair VF filter pump, WhisperFlo 2 hp WFE-8 waterfall pump, WhisperFloFX 2 hp spillover spa pump
    Intellibrite 5G (2 pool and 1 in spa) lights :: TFT-100 test kit, Taylor K-1776 test kit
    Re: How to fix flange for Pentair IC40?
    I wish my 3-way valve only dripped ever 2 seconds ... I have a steady drip and almost a stream
    I would guess the black fitting is CPVC, but an not sure. I doubt you can put any "glue" on the outside and have is last as a repair very long ... maybe if you use a universal solvent and then put a hose clamp around it to hold together?
    Mod Squad pooldv's Avatar
    DFW, TX
    Yes, that is CPVC, so would need to use CPVC glue, like Oatey orange. +1 on a drip every 2 seconds isn't really a leak.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    For such a small leak, I think JB Weld will fix it. You just have to get the right JB weld product for the application. Either JB "water weld" or JB "plastic weld" would likely do the job.
    Divin Dave,
    IG Vinyl, 15' x 30', 3 1/2' - 6' deep, Oval, ~15K gal, Intelliclor IC40, Intelliflo VS pump, Clean and Clear 420 Filter, auto-fill-disabled, Retrofit LED Color Light, Dolphin Nautilus Robot, TF100 Test Kit, Taylor K1766 Salt Test Kit, Tftestkit Pressure Gauge. Experience- it's what's learned just after you needed it most !!
