Thread: CH and Scale Question
    Apr 2016
    Las Vegas
    20
    Would you consider CH of 525 warranting the use of a regular anti scaler? If so what product do you recommend?
    -KP
    Specs:
    IG Pool, ~20,000 gallons, re-plastered in 2015.
    1.5" plumbing, single drain/skimmer.
    Pentair Intelliflo 2 VST Pump, Clean & Clear 420 Cartridge Filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Bioguard Stain and Scale ingredients
    525 CH is normally fine. Certainly by itself it does not warrant the need for a scale inhibitor of any kind. The important number is the aggregate value of your CSI. This takes into a account your pH, TA, CH, temperature, CYA, salt... etc to indicate whether or not you will have scaling, neutral or corrosive conditions.
    Can you post a full set of test results, especially pH, TA? If you can post those, we can walk you through how your CSI looks.
    http://www.troublefreepool.com/calc.html
    Are you referring to numbers for your pool or for a spa? Just asking because of the forum location of this thread. If it's for a pool, I can move it to an appropriate forum as it is.
    Isolated Spa - 345 Gallons
    Apr 2016
    Las Vegas
    20
    Sorry JV, it is for the pool.
    -KP
    Specs:
    Feb 2014
    Central Minnesota
    5,080
    Re: CH and Scale Question
    525 ppm CH is very manageable for your pool. If you can post full test results, I can give you recommendations on where you should try to keep your pH and TA to avoid scaling.
    With a slightly high CH, you'll want to make sure you lower your TA to 70-80 ppm and then you should be fine as long as you keep your pH at 7.8 or less. No need to use a scale inhibitor product if you do this.
    Apr 2016
    Las Vegas
    20
    Thanks JV. My TA is usually 110-120, so I need to keep up with it more. So far I havent noticed any runaway scale but there is some evidence at the water line around the tiles.
    -KP
    Specs:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,179
    Waterline and saltwater cell are the first two places where it starts to show up.
    More here on lowering your TA, Pool School - Lower Total Alkalinity
    More about scale here, Pool School - Calcium Scaling
