Results 1 to 9 of 9
Thread: Do I need to close an inground pool in central florida?
    Sep 2016
    Tampa, FL
    17
    Post Do I need to close an inground pool in central florida?
    Hello all,
    I'm new to pools and this forum but I can already sense I'm in the right place. I'm currently getting ahead of an algae issue due to high CYA and too many tablets in the past.
    Should I close my pool for the mild Tampa area winter? Pool is screened in and could definitely use some rain water to drain at no charge and reduce my CYA.
    What are the real reasons for "closing". I just moved to the Tampa area so I don't really know what to expect from the winter. Below is a screenshot of what wikipedia has to say
    In the winter, average temperatures range from the low to mid 70s F (2124 C) during the day to the low to mid 50s F (1013 C) at night. However, sustained colder air pushes into the area on several occasions every winter, dropping the highs and lows to 15 F (8 C) or more below the seasonal averages for several days at a time. The temperature can fall below freezing an average of 2 to 3 times per year, though this does not occur every season
    Tampa, FL 16,000 gallons, concrete in ground screened pool, Sta-Rite 70sqft cartridge filter, Marathon 3/4 Pump, city water. I test with Taylor K-2006
    33,888
    Re: Do I need to close an inground pool in central florida?
    I would not think you need to close as outdoor pool in FL let alone an indoor one.
    Just maintain adequate FC for your CYA level. And if the temp drops below freezing at night, run the pump.
    This is what I do as the climate is fairly similar with a few nights dropping below freezing.
    Sep 2016
    Tampa, FL
    17
    Thank you jblizzle!
    Just for clarity with inside you meant screened in, right?
    33,888
    Sorry I misread your title and thought you said indoor pool.
    A screened in pool would be basically treated the same as an outdoor pool
    Sep 2016
    Tampa, FL
    17
    That's what I thought...thanks.
    What are the main reasons for closing a pool? Debris/freeze? I understand some are antithetical while others might cause serious issues.
    28,835
    Freezing (hard) temps are far and away the primary reason.
    Dave S. - Forum owner
    pabeader's Avatar
    May 2015
    Dallas Ga
    3,245
    Just a quick note: I don't close mine. Don't even cover it. Just put a mesh tarp over it until the leaves stop then remove it for the winter. Adjust pump to run mostly at night. I'm in north-central Georgia.
    Bob - Palm Beach by San Juan Pools. approx 5000 gals Pentair 320 cartridge filter (all new guts installed by me) Goldline SWG Intermec 104 TImer Test kit: TF-100 w/Speed Stir
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    446
    You definitely do not need to close it. There is no way enough ice would ever form to break your pipes.
    If it gets cold enough in Central Florida to freeze pool lines they will be the least of our issues
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Sep 2016
    Tampa, FL
    17
    Thank you all!
