Thread: Skimmer Leak?????
    Jun 2016
    Opelika/Alabama
    18
    Skimmer Leak?????
    So, I've posted a few times before about my Mother in Laws Pool issues, which there is no short fall of. Well we have stopped taking care of the pool for the year because of what the Pool Store called 'Hundreds of Pin-Hole Leaks'. Well, after letting the pool sit for 2 weeks now, the water has definitely stopped leaking, and it has stopped directly underneath the Skimmer Box. After about 4 days the leaking stopped and now we are only losing minimal water due to evaporation (did the bucket test to make sure.)
    Does this mean that the leak could potentially be the Skimmers? Or is it still a possibility it is the Pin-Hole Leaks that they detected? How do we tell what the case is because if it is a Skimmer leak isn't it fixable? A new Liner is what we were told we need which may be true but if it is fixable I'd like to go that route.
    Info on the pool should be in my signature but here is a recap:
    ~30-35k gallon
    - Vinyl Pool
    -IG
    -2 Returns (Jets)
    - 2 Skimmer boxes on each side of the pool
    Thanks so much!
    30,000 gallon IG Vinyl/Hayward S220T Sand Filter with Hayward 1 HP super pump
    ps0303's Avatar
    Jul 2011
    FL
    2,811
    Re: Skimmer Leak?????
    Where did "they" say the pinholes were located it? Are the below or above the current water line?
    Paul
    http://www.gastekservices.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2016
    Opelika/Alabama
    18
    Quote Originally Posted by ps0303 View Post
    So I wasn't there when they inspected it, but my MIL did say that they told her there were more pin holes than they could detect. I will ask her tomorrow to be sure but it seemed pretty obvious that since she fired them for maintenance and upkeep they immediately found the most expensive fix to take her money.
    To be fair, I am not the best looking pool boy but I do save her money, so there is that.
