Results 1 to 17 of 17
Thread: New to pool, forum and everything
    Sep 2016
    Tampa, FL
    25
    Hello,
    I purchased a pool with a house in the Tampa area 4 weeks ago.
    I've been doing a good bit of searching to come prepared to the task at hand, which is maintain my pool with no professional intervention. Unfortunately I came across this forum a couple of weeks too late.
    Previous owner has been using packs for a while I believe and I thought it would be ok to continue. Testing my water regularly I was pleased with my chlorine levels (always around 4-5ppm). (All the other chemistry in check). Unfortunately I realized late that a CYA of 100 is not cool, even in Florida So last week I got algae.
    I might have Clorox written all over my pool now but following the suggestions on this forum I think I got the upper hand...
    Thank you all for your help and professionalism
    Tampa, FL 16,000 gallons, concrete in ground screened pool, Sta-Rite 70sqft cartridge filter, Marathon 3/4 Pump, city water. I test with Taylor K-2006
    Jan 2012
    'burbs of Augusta, Georgia
    7,180
    Re: New to pool, forum and everything
    Welcome to TFP, Colon001 Its not too late to take charge of your pool and water!
    First off- have you read our recommendations on proper pool testing yet?
    Pool School - Test Kits Compared
    Sep 2016
    Tampa, FL
    25
    Thanks YippeeSkippy. Yes I'm equipped with Taylor K-2006. When I feel lazy and need to run to the local pool store (Pinch a penny) I also get them to test my water. I noticed they use the professional version of the test kit and their results converged with mine, so I assume they're reliable.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    1,904
    I don't understand that line of reasoning. If I do the FAS-DPD test and pH that is a minute, max. The whole test, including CYA, takes 5 minutes, maybe.
    A round trip to the pool store for questionable testing would take a bare minimum of 10 minutes. 3-4 times a week and I've spent more time going to the pool store than the grocery store that week.
    The fact you thought you had a CYA of 100 just hammers it home. Not trying to be rude, just
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Sep 2016
    Tampa, FL
    25
    I meant that if I have to go to the store I also bring the water along...
    What do you mean with:
    Quote Originally Posted by Mr Bruce View Post
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    1,904
    Quote Originally Posted by colon001 View Post
    I'm sorry, I misread your post about CYA.
    I'm curious what you go to the pool store for? I haven't been to one in a VERY long time
    Sep 2016
    Tampa, FL
    25
    Thanks. Well I needed to buy chlorine because of algae problem (due to high CYA I assume)...and yes...I cracked and bought algae killer (shame on me )
    Speaking of which, now that I introduced 4 caps full of sodium bromide anything in particular I should be in the lookout for?
    Jan 2012
    7,180
    Huh?! Why would you put bromide in a chlorine pool? Pools are either one or the other sanitation system, and once bromide is in the water the only way to get it out is to drain it. Bromide pools are not particularly easy to care for from what I've read.
    I just don't understand.
    Sep 2016
    Tampa, FL
    25
    It was the main ingredient in an algaecide that was recommended (yellowtrine)...
    I now understand a bit more about the mistake.
    What would be the implications now?
    Jan 2012
    7,180
    Well, from what I know (and that's not saying a lot) it will increase your chlorine demand. Possibly a lot.
    Bromine pools will always be bromine pools until the water is changed, because when you add chlorine that re-charges the bromide again.
    It's all a little too sci-fi for me at this point but I'll see what information I can find for you....
    Mod Squad pooldv's Avatar
    DFW, TX
    24,259
    That sums it up pretty well.
    From this article, How do I use Bromine in my spa (or pool)?
    With sodium bromide in the water the first x amount of chlorine you add will be used up oxidizing the bromide ions into hypobromous acid which will read as bromine on your chlorine test. So, you will never really know how much chlorine is in the pool because some of it will be bromine.
    Jan 2012
    7,180
    Ok, I've done some Googling and from what I gather since you added a bromine algaecide in smaller quantities you *might* get away with it if you don't add ANY more of that yellowtrine, and you'll probably need a LOT more chlorine for a while. It might burn off over time with sun exposure.
    How long? Who knows?? Be prepared to need more chlorine though...
    Keep me posted?
    Yip
    Aug 2014
    Northern IL
    4,615
    Don't panic. Sunlight can eventually convert bromine into permanently inactive bromates. How long does this take? It's hard to tell because every pool is different. Just stick with liquid chlorine now and keep a close eye on things.
    I did this many eons ago and I had a totally bromine pool, not just 4 capsfuls of something. You should be okay.
    pabeader's Avatar
    May 2015
    Dallas Ga
    4,077
    Oh, and no need to go to pool $tore for chlorine when you can get it at the grocery or big box store. No chance of getting something you don't need for your pool.
    Bob - Palm Beach by San Juan Pools. approx 5000 gals., Pentair 320 cartridge filter (all new guts installed by me), Goldline SWG, 'New to me' Kreepy Krauly Sand Shark, Intermec 104 Timer Test kit: TF-100 w/Speed Stir
    Sep 2016
    Tampa, FL
    25
    Great guys! Thank you all so very much! I feel relieved. I'm puzzled how lightly these products are sold in stores without informing about the consequences.
    On the bright side, should bromine work as a sanitizer too? Not that I want to go in that direction but it should still contribute to the overall effort?
    I hear ya!
    Quote Originally Posted by pabeader View Post
    DFW, TX
    24,259
    Yes, the bromine will contribute to the sanitizer effort.
    Sep 2016
    Tampa, FL
    25
    Thank you pooldv!
