Thread: What should I be spending for a winter safety cover? $700 or $3000????
    May 2016
    Toronto
    130
    Hey,
    First time owning a pool and have never done a closing. I live in Toronto.
    Shopping for a pool safety cover for the winter. Why are some like $700-$800 and others like $3000-$4000? Is it just the quality?
    What should I be looking for.
    These are the few i am looking at:
    Covers :: Safety Covers :: Rectangle with Center Step Stock Safety Covers :: 16 x 32 ft Rectangle with 8 Ft Center Step Stock Safety Covers :: 16 x 32 ft Rectangle with 4 x 8 ft Center Step Safety Cover Sunshade 95 Mesh
    Covers :: Safety Covers :: Rectangle with Center Step Stock Safety Covers :: 16 x 32 ft Rectangle with 8 Ft Center Step Stock Safety Covers :: 16 x 32 ft Rectangle with 4 x 8 ft Center Step Safety Cover Lite Solid
    Not sure what to look at and compare between brands and what I should be spending.
    Any help would be great.
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,876
    Re: What should I be spending for a winter safety cover? $700 or $3000????
    It's all about quality of materials & construction and brand markup. Both are real things and contribute to the higher prices. Really tough to give advice on that topic. It's about what you value. When the difference is of that magnitude, there is usually also some relationship to how long it will last. FWIW - I went with a premium brand and paid over $3K (USD). Any differences would probably start to evidence themselves over the mid-term, like 7-10 years I'd suspect.
    The cheaper covers will certainly cover you pool and be safe initially. At what point the fabric becomes brittle and fails (or other failure), it's tough to say.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2016
    Canada/Toronto
    6
    I'm in Toronto also and just recently purchased a safety pool cover. If you have a rectangular shaped pool then you should be able to get one of those preset sizes and not go the custom route like i did.
    There are differences in quality ie the amount of permeability of the mesh, spring and mesh quality but it shouldn't be that big of a difference if you are comparing apples to apples ei 95 mesh vs another 95 mesh.
    Oh and i forgot about the installation. The ones that you linked to is just for the cover and no installation.
    May 2016
    Toronto
    130
    Quote Originally Posted by pool_new View Post
    I can install it myself
