Thread: Drop Out - flocculant
    Jul 2015
    Marietta, Ga
    My neighbors and I follow the TFP
    method of closing our in ground pools. The 2 long time pool owners swear to adding a flocculant named Drop Off after you finish adding the Poly 60. Both testify how when they open in spring, they remove their cover. vacuum the bottom of the pool to remove settled algae and degraded containment
    to waste, shock with bleach, run the pump for 24 hours, test and balance and open in less than 2 days! My question is, "ANY" downside to adding a flocculant when closing? Thank You!
    20K, IG, new Merlin vinyl liner, sand, Triton Tr-60, Eco-Pump EP-6, 1.5hp, Taylor TF-100
    Test kit, Compupool CPSC 24 SWG, city water, built in 1979.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    Re: Drop Out - flocculant
    If it is not needed (99% of the time) it is a waste of money. Some flocculents drop pH a lot, so you'd have the headache of raising pH again.
    Most of us simply run our pools as normal until the temps drop into the 50s. I have never added polyquat or anything special to mine to close.
    Here was this spring What did you do to your pool today? - Page 72
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2012
    'burbs of Augusta, Georgia
    Any floc that gets into the filter risks gumming it up. Clarifiers and Flocculants just aren't something we recommend as necessary and can cause you more grief than they claim to fix. Why risk it?
