Results 1 to 12 of 12
Thread: help with solving water cloudiness
    May 2011
    Miami, FL
    168
    Hello
    After some weeks of steady rain a few weeks back here in Miami, my pool water remains cloudy. The pool is algae free, and looks clean, but the deep end looks mirky.
    TC 5.0
    FC 5.0
    ph 8
    TA 75ppm
    Calcium hardness 180 ppm
    Stabilizer 50
    These are the numbers from a local pool store that I do trust, and I added Calcium hardness and TA increaser AFTER. I also added 7.5 gallons of chlorine (3 jugs). The pump has been running for a good time (6-8 hours daily), but the cloudiness/haziness remains.
    What else can I do or check?
    Thank you
    16,900 gallon inground pool (16x30 with spa bench)
    Sta-rite cartridge filter
    Diamondbrite surface (i think. I am not original homeowner).
    1.5hp Hayward Super Pump
    Hayward Navigator Pro suction cleaner with V-flex kit
    29,872
    Re: help with solving water cloudiness
    What does the pool store say?
    Dave S. - Forum owner
    May 2011
    Miami, FL
    168
    My wife took the sample, and I am going to assume that she mentioned the cloudiness. Based on the numbers, they stated to add alkalinity increaser and calcium hardness.
    29,872
    What your pool needs the most is muriatic acid. Your pH should ALWAYS be in the 7's. I would lower it sooner rather than later.
    I assume your cloudiness may be from the calcium chloride but you don't say how big of a dose you applied.
    Run your pump 24/7 until it clears and brush the bottom of the pool from time to time.
    I would have left TA alone.
    May 2011
    Miami, FL
    168
    thank you Dave. So, they said to make an already basic pool (ph of 8) more basic by adding 5 pounds of sodium hydrogen carbonate? Wow.
    You stated that I added calcium chloride. When/how did I do that? I ask to learn, not to question or doubt.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Calcium hardness
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    May 2016
    West Bloomfield, MI
    563
    Quote Originally Posted by nabril15 View Post
    Trust in pool stores doesn't last very long on here... I bet their CH figure was off by at least 50% too.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    May 2011
    Miami, FL
    168
    the cloudiness is mostly gone. My latest numbers
    ph 7.8
    TA 75
    CH 225
    TC 4 and FC 4
    I am being told to add TA increaser, but I'm not sure with a ph of 7.8. I need some acid, right?
    Jun 2015
    Glendale, AZ
    156
    ph 7.8
    TA 75
    CH 225
    TC 4 and FC 4
    What you need in a real test kit (see recommended) and do your own tests, then post the numbers, including CYA
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    May 2011
    Miami, FL
    168
    Ok. So in the name if education, can we assume that those are my numbers. A oh of 7.8 doesn't need more sodium bicarbonate. Correct?
    Jun 2015
    Glendale, AZ
    156
    At the top of the page click on 'Pool Math' gives you all the recommended numbers for your pool.
    Jun 2014
    12,782
    Correct. 7.8 is at the top of the scale, so anything higher and you want to use muriatic acid to lower as noted on the Recommended Chemicals link below in my sig. A TA around 70-80 is fine as well (if we assumed that was accurate). Once you obtain your own test kit, you'll see what we mean. Keep us posted.
