Thread: Oceanside Ca Pool Build - May 2016
    sddiver's Avatar
    Mar 2016
    Oceanside, Ca
    15
    Hello all,
    My plan was to document our build process all along the way, but time got away and that didn't happen so I wanted to share our experience post build. We stared discussing the pool idea around the fall of 2015 after water restrictions led to our backyard going from a beautiful oasis (well not really but...) to a neglected dead weed patch that was no joy to look at. The kids were at the right age (7 and 10), and able to swim and love the water (as do we) so a pool seemed like the perfect idea to anchor a backyard renovation. We looked at both owner builder (I have done some fairly involved DIY projects over the years so was not afraid of the OB route) and the traditional PB route and after some deliberation decided that the PB route would ultimately result in a more timely completion in our case (given the amount of time I would be able to give to the build). Ultimately we liked Premier Pools and spas and selected them as the builder after talking to 3 other companies. I was clear with the builder that I didn't care for their design so if we signed I wanted them to provide their CAD files from Pool Studio and I was going to modify them (staying within the lineal footage and square footage we were contracting with them). Once we signed I deleted their design and started over, adjusting my design to meet the agreed upon sizing. Pool Studio has a definite learning curve but after some practice isn't too difficult to get excellent results from. The revised drawing was given back them (not without some hiccups - they sent their original plan into their plan drawing sub which created the detailed build plans from that original design, so they had to have it re-done based on our revised plan before we could start the physical layout marking). Anyway - on to the build which commenced Ma 5, 2016:
    Pool layout on the lovely weed patch:
    Starting the Dig May 5, 2016:
    Rebar May 13, 2016 /plumbing May 14-16, 2016:
    Gunite day May 23, 2016!
    Oops - baja shelf collapsed during gunite application:
    Under the "you had one job" catagory - the dog was allowed to explore the gunite shortly after the crews left... can you tell?
    Coping/Ledger stone/Glass Tile/waterline tile - 30 day wait for Pacific Stone custom coping to be fabricated (had to template off bond beam after gunite).
    Coping arrived June 24th, 2016 installation completed by July 1:
    Dam wall glass tile:
    Laminar installation (I did this installation myself, had PB plumb 6 lines for deck jets, which I installed (decided to use 2 of the lines for LED Laminars and the other 4 for deck jets - LOVE the laminars):
    1800 sq ft of Decking (not done by PB, contracted separately) July 14, 2016:
    Plaster day! Aug 8, 2016 (Wet Edge Satin Matrix Tahitian Tropical)
    Plaster completed:
    Pool filled - Aug 9, 2016 (used 4 hoses - started mid - morning completed by midnight)
    Equipment pad:
    Finished Pool:
    Mistake #1 - Nature2 mineral/tab dispenser. I removed this after the build and replaced it with a Jandy Aquapure 1400 SWG system - PB said an ozone system with mineral dispenser was better than a SWG and was offering it at the same cost - unfortunately I did my research after the fact and then determined unequivocally that I wanted a SWG system (left the ozonater hooked up for the minor benefit it provides - knowing it oxidizes some of the FC). As soon as the 30 days was up for the plaster to cure I salted the pool and installed the Jandy SWG.
    Mistake #2 - PB did not mention that almost any water feature (sheer descents were always in the plan) should be supplied from a filtered source. Our plan included a separate water feature pump, but no mention was ever made of the need to filter it. In their defense it became mandatory once I decided to install the laminars which MUST be filtered.
    That being said I installed a filter (Jandy CS150) in the water feature loop. I also took the opportunity to correct a couple sloppy details by the PB:
    1 - they installed a check valve on the discharge side of the pump, meaning the pump lost its prime any time the basket was accessed - so i replaced the check valve and put it on the suction side.
    2 - the auto fill was sloppily connected from the top of a nearby hose bib and the PVC pipe was routed across the eq pad so i took the opportunity while installing the filter to also tap into the water pipe underground to supply the autofill.
    That's our build story - the process really moved along quick quickly without any major unexpected delays. The overall experience was a good one and we think the builder overall did a very nice job. We are loving the pool and I have really appreciated all the information and participation by the users of this site - it's a great resource and community.
    18500G Freeform IG pool & spa. 39'x19' Wet Edge Satin Matrix Tahitian Tropical. AquaPure 1400 SWG, JXI 400K BTU HTR, VSSHP270AUT 2.7HP VS PMP, 460CF + CS150 Cart Filter, PFPF2.0 2HP jet pump for spa jets, 1HP wtr ftr pmp Jandy LED RGBW 9W Nichless lights (3x-pool, 1x-spa), 2 - 24" sheer descents, 4 - deck jets, 2 - LED Laminar jets, Construction start 5/5/16 - Fill date 8/9/16. SD County SoCal (Oceanside). TF100 test kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    31,549
    Re: Oceanside Ca Pool Build - May 2016
    Thanks for sharing! It sounds like it went as well as other builds. There seems to always be a hiccup or two....but the water features not being filtered----ouch
    Glad you changed over to the SWG. Shame it was after the other was already paid for and put in but all is well that ends well!
    What color grout did you use for your glass tile? It blends in nice!
    sddiver's Avatar
    Mar 2016
    Oceanside, Ca
    15
    thank you! the grout was labeled as silver, but looks dark grey. the mastic behind the tile was white.
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Very pretty!!
    So, this is the first I've heard of water features being filtered. How does someone check their equipment for that?
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    sddiver's Avatar
    Mar 2016
    Oceanside, Ca
    15
    If your water features are connected to the main pump they would be filtered since that is also the filter loop. If you have a separate pump for water features you would see the discharge side of that pump going to its own filter and then back to the pool. In our case laminars are very sensitive to any debris so having it not filtered initially led to the little screens plugging constantly and reducing the laminar stream to a trickle.
    Killer95Stang's Avatar
    Sunny SoCal
    620
    I only have two bubblers and rock waterfall, so I don't see any advantage to filtering the secondary feature pump. They are pretty much full flow with no restrictions to the outlets. I can see it need with laminars and deckjets.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
