Results 1 to 8 of 8
Thread: Pentair Dynamo 1.5 hp stopped working
    May 2015
    RedBud,IL
    42
    Was doing my routine maint and shut the pump off, went to restart it and it just hummed. Typically I would say the capacitor was shot but can't find one on it? Funny thing is I decided to go ahead and close it for the winter amd worry about it in the spring, so I pulled it off. Plugged it in on the bench and gave it a spin by hand and now it runs? Any thoughts?
    21 ft agp, 1 Hp Pentair Dynamo pump, Pentair sand dollar filter with Intex Swg.
    mas985's Avatar
    Pleasanton, CA
    11,290
    Re: Pentair Dynamo 1.5 hp stopped working
    There is no capacitor in the end cap of the motor?
    Is there centrifugal switch?
    Could be corroded contacts.
    Did it spin easy by hand?
    Once running did it make a lot of noise?
    Mark
    18'x36' 20k plaster, 1/2 HP 2sp pump, Aqualogic PS8 SWCG, 420 sq-ft Cartridge, Solar, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater
    May 2015
    RedBud,IL
    42
    Sorry it took so long to respond. No capacitor in it that I can find, It does have a terminal block in it for the ac line and the switch-Maybe that could be it. Now it does have what acts like a clutch that spins in and engages when it starts. Once it was running on the bench it sounded normal however the pump was empty and there was no load on it. Didn't want to run it to long dry. It's about 9-10 years old now so maybe it's just time? It spun freely by hand as well.
    mas985's Avatar
    Pleasanton, CA
    11,290
    That is a centrifugal switch. Check the contacts for corrosion.
    Mark
    May 2015
    RedBud,IL
    42
    OK, Where would they be located. Used to dealing with brush's at work. never seen one like this.
    mas985's Avatar
    Pleasanton, CA
    11,290
    The switch is right on top of the governor. Look something like this:
    Mark
    May 2015
    RedBud,IL
    42
    Ok. Would a shot of contact cleaner do it or would I need to sand them off if there's any corrosion?
    mas985's Avatar
    Pleasanton, CA
    11,290
    Emery cloth would probably work best but sand paper can work in a pinch.
    Also you can check to make sure the switch is aligned to the governor.
    Mark
