Results 1 to 7 of 7
Thread: Adding Hardness Plus?
    Feb 2013
    Jupiter, Florida
    73
    Our local Leslie's instructed me to add 20LBs of Hardness Plus to raise the calcium level. OK, no problem. However, they tell me (and have numerous times in the past) to add 5 lbs. one day, recirculate, 5 lbs the next, 5 lbs the next and 4 days later the last 5 lbs. The instructions on the bucket mention nothing about spreading it out over a period of time. Why does the pool store say to do this? What is the benefit? The only think I can think of is that it allows you to measure the level as you are adding, see where you are each day. Any comments appreciated!
    2006 IG 18.6K gal marcite saltwater w/integrated 800 gal spa, spillover, 2 Main and 2 Spa Drains, 2 Skimmers
    Goldline Aqua Logic PS-8, Aqua Pod Remote, Hayward GLX-Cell-15-W SWG, Hayward Pool Vac XL, Cartridge filter, single speed pump
    Taylor K-2006, Lamotte Borate Strips
    30,107
    Re: Adding Hardness Plus?
    Dropping a big dose of calcium chloride can cause clouding in your pool and take a long time to clear up......that's why they suggest it in doses.
    What is your CH anyway? You may not need any.
    You didn't ask this but I would also suggest your stay OUT of the pool store and do your own testing.......pool stores are not helpful in maintaining a pool correctly.
    Feb 2013
    Jupiter, Florida
    73
    Thanks. Their reading was 180. Mine was 300. However, I am getting readings that don't match any of theirs. I think my test kit reagents are old as the kit is 2 years old. My PH as way lower than theirs, my Chlorine was 2 when theirs was a high 4.5. Usually they are pretty close. Think it is time for new reagents? One other piece of info is that I consistently have a white "powder" that settles in my spa. I always though it was calcium that is settling. No one can seem to tell me what it is. It's not salt (SWG pool). If it is calcium I'm not sure whether it is from having too much or too little....
    Mod Squad pooldv's Avatar
    DFW, TX
    24,042
    Which test kit are you using?
    More here about adding chems to your pool, Pool School - Recommended Pool Chemicals
    Feb 2013
    Jupiter, Florida
    73
    Quote Originally Posted by pooldv View Post
    I have the Taylor K-2006, complete kit. The reagents look fine, no change in normal color but when I do simple PH and CL tests, repeating them to verify, I get a wide variance from the pool store then something is off. I am always leery of their advice and purchase suggestions (Phos-Free, etc.) and am completely allergic to their prices.
    domct203's Avatar
    Jun 2015
    CT
    3,383
    Quote Originally Posted by firstbase View Post
    The reason that their results differ from yours is because theirs are wrong. Get some new reagents and trust your test results.
    If you do two FC tests in a row from the same sample, does your test result repeat within 0.5-1ppm with the 10ml sample size (+/- 1 drop)?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2016
    West Bloomfield, MI
    668
    That's aligned with my experience: that of their testing, their CH results are the poorest. Not only did their results not agree with mine, but they also didn't agree with the calculations of a fresh fill and carefully measured additions of calcium chloride.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
