Thread: My panel of numbers...almost closing time
    Aug 2016
    Fowlerville
    10
    Water is crystal clear for once (been battling with it all summer). Here are my numbers from my TF-100 kit:
    Chlorine 2
    Br 4
    PH 8
    FC 1.5
    CC 0
    CYA 90
    CH 325
    TA 200
    Not sure what to do to get everything stablized before we close it in a week or two.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    542
    Re: My panel of numbers...almost closing time
    I'm sure you know this already, but your chlorine is very, very low for your CYA. I can't see information about your pool in your signature but your pH is also on the high side, as is TA.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Mod Squad pooldv's Avatar
    DFW, TX
    22,940
    Please add your pool info to your signature so that we can better help you. More here on what to add and how to do it, Pool School - Read This BEFORE You Post
    Aug 2016
    Fowlerville
    10
    Quote Originally Posted by pooldv View Post
    Sorry, I meant to do that before I posted:
    24' round AG (~13,500gal), vinyl, sand (Doughboy Aquaview AS Model 0-1709-020), TF-100 test kit
    I just updated my siggy but it's not showing up yet.
    I have a box of granular shock I would like to use up so can I add that to get my chlorine up or should I just do bleach? Lower TA with muriatic acid?
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    542
    What does your granular shock contain? Yes, MA to get your pH back in line. Get your CL in line as well and then read the closing how-to
    Aug 2016
    Fowlerville
    10
    I have a box of 1# packs of Clorox Shock Plus (Active Ingredient Sodium dichloro-s-triazinetrione). I did end up doing 1 pack Monday and then .5gal MA 2 days ago. Here are my numbers from this morning:
    pH 7.2
    Cl/Br 5/10
    CYA 100
    FC 3.5
    CC 0
    TA 190
