Thread: Salt test strips
    Pepo's Avatar
    Mar 2015
    Orlando, Florida
    12
    Salt test strips
    Hello,
    Just want to get some feedback on how accurate are the salt test strips from the tfp online store?
    Thanks!
    15k Gal. ig Pool & Spa quartz plaster, Hayward super pump II 2.5 HP, Hayward 425 sf. cartridge filter,
    PS-4 Goldline automation, SWG(not working) using liquid chlorine now, Hayward 250k BTU propane spa heater.
    mas985's Avatar
    Pleasanton, CA
    11,280
    Re: Salt test strips
    In general, salt strips will have a limited shelf life and in my experience, not very accurate. I would get a drop kit instead. It is much more accurate and lasts until you run out of reagents.
    Mark
    18'x36' 20k plaster, 1/2 HP 2sp pump, Aqualogic PS8 SWCG, 420 sq-ft Cartridge, Solar, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater
    Mod Squad pooldv's Avatar
    DFW, TX
    23,654
    I have the aquachek strips and they are ok. Not very accurate is correct. But, they've been close enough to keep my SWG happy for 5 seasons.
    JoyfulNoise's Avatar
    May 2015
    10,773
    The reported tolerance of the Aquacheck strips is usually about +/-400ppm. However, they are affected by humidity and the people neglect to read the instructions where they specifically say that the strip must be placed in a test tube filled with about 1" of water. And every bottle of strips is different because the number on the strip is calibrated to a chart on the bottle.
    The K-1766 drop based titration test uses a 10mL water sample volume and has a tolerance of +/-200ppm (the titrant precision is 200ppm/drop). However, one can simply use a larger water sample and get better precision - a 25mL water sample will have a titrant precision of 80ppm/drop. Also, the K-1766 measures the EXACT chloride ion (Cl-) concentration and has no interferences associated with it (unless you add cyanide or bromine to your pool water). So the salt level determination from a K-1766 is a very accurate representation of the salinity level of your water.
    Matt
    Pepo's Avatar
    Mar 2015
    Orlando, Florida
    12
    Thanks all for the info
    I will go with a drop test!
