Results 1 to 10 of 10
Thread: At a loss on next steps
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Back around the middle of July, my spider gasket failed, and running the pump/filter overnight would result in a 3-4 in water loss. The only way to stop the water was closing the valves near skimmer and the outflow.
    Intex doesn't sell just the gasket, and I have to replace the 6-way valve, which is fine - it's under 50 dollars. However, they are OUT OF STOCK.
    They told me the ETA for more was the end of August. Now they are telling me it is the end of October.
    My pool has sat untouched since the middle of July, and is a nasty green swamp.
    I would close the pool if I could, but with the pump/filter rendered useless, I don't even know how to close it. The past two years we left the pool up, but covered, and the pool was clean.
    I don't know what to do now.
    Ideas anyone?
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    Texas Splash's Avatar
    Jun 2014
    12,981
    Re: At a loss on next steps
    I suspect the colder weather shouldn't drop down for another month or so huh? If you could wait until the parts come in, you might be able to start your SLAM before closing. If you leave it and close while green, you can expect a tougher opening and possibly an ammonia issue as well. While waiting for the new parts, have you considered using a submersible pump (if available) to simply keep water and chemicals moving around? There's no filtration, but at least you have some movement and can add some bleach while you wait. Just a thought.
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    I do have a sump pump, but it's pretty wimpy. At this point, if I start adding bleach, but unable to SLAM, won't it just become a gray, opaque mess that will just "eat up" the bleach I put in there?
    I suppose I could use the net and get the leaves and larger debris out.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    Have you searched the internet for other sources of the part? You can search on the part number for the specific part, from the parts list in the owners manual (which you can also find online).
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    domct203's Avatar
    Jun 2015
    CT
    3,376
    Quote Originally Posted by Chewbubba View Post
    Ideas anyone?
    While I can see that the filter may not be usable because of the multi-valve, but the pump still works, right?
    Why not disconnect the filter from the pump, and hook up the pump directly to the pool? This will keep your water circulating and allow you to start a SLAM while you weigh your options.
    If you had done this as soon as the filter went down, your pool could have remained clear.
    You should have immediately removed the leaves and larger debris regardless of your filter situation. I recommend you do that right away.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Quote Originally Posted by GaryT58 View Post
    Intex does not sell the gasket separate, nor do they list it in the manual. I figure they expect owners to leave it alone and not go taking it apart (which I've done the last 2 seasons when winterizing the pool).
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Quote Originally Posted by domct203 View Post
    That's a great idea. It's not going to remove dead algae though, so I don't figure there is anything I can do about that (can't vacuum either). I'll start fishing the leaves and twigs out asap.
    Jun 2016
    Panama City
    97
    Why not drain it? It's only 6000 gallons. I have a 17' 52" and if I had that problem....I'd just pull the plug! Way less problem to just refill. eBay has your parts! Search and buy a used one!
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    Sorry, I meant the 6-way valve. If you have part # can search for it.
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Quote Originally Posted by JEC11718 View Post
    Another good idea. I'll probably wait until I get the parts and just refill then.
